vortexe90
D+ and D- as standard output |
Posted: Tue May 21, 2013 3:31 pm |
I used a 18F4550 and I put LED connect to the USB port (D + and D-) and PIN_C4 PIN_C5 respectively, but both PIN not want to set as output.
is there a configuration that make these two PIN as standard output.
this is the configuration that i used....
Code: | #include <18F4550.h>
#device adc=10
#FUSES PLL1 //No PLL PreScaler
#FUSES CPUDIV1 //No System Clock Postscaler
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES NOVREGEN //USB voltage regulator disabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC //Timer1 configured for higher power operation
#FUSES NOMCLR //Master Clear pin used for I/O
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES ICPRT //ICPRT enabled
#use delay(crystal=20000000)
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=gsm)
#use RS232(baud=9600,parity=N,xmit=PIN_D1,bits=8,stream=xbee)
#use fixed_io(c_outputs=PIN_C4, PIN_C5) |
Joined: 01 Jul 2010 Posts: 9229 Location: Greensville,Ontario
Posted: Tue May 21, 2013 5:32 pm |
this is one of those 'you GOTTA read the manual/datasheet' themes...
as cut and pasted from the PIC18F4550 datasheet...
Page 15, Table 1-2
RC4/D-/VM
RC4
DVM
15
I
I/O
I
TTL
TTL
Digital input.
USB differential minus line (input/output).
External USB transceiver VM input.
RC5/D+/VP
RC5
D+
VP
16
I
I/O
O
TTL
TTL
Digital input.
USB differential plus line (input/output).
External USB transceiver VP input.
...clearly states what the pins can be used for.
NOT all PIC pins can be used for outputs and inputs !!
hth
jay |
