Main function knows, if it was an interrupt
pavelustinov
PostPosted: Fri Apr 12, 2013 6:23 am     Reply with quote
Hello everybody!
I use interrupt in my program like this
#INT_EXT
void ext_isr(void)
In interrupt function I save settings to EEPROM.
How can main function know, if it was an interrupt?
Main function must read settings from EEPROM once, because read it every second is a bad idea.
Maybe something like a global variable?
asmboy
PostPosted: Fri Apr 12, 2013 8:07 am     Reply with quote
int1 flag=0; //gobal inited to zero
#INT_EXT
void ext_isr(void)
flag=1;
if (flag) {  write_eeprom(whatever); flag=0; }
NEVER write_eeprom inside an ISR - takes too much time
PostPosted: Fri Apr 12, 2013 8:09 am     Reply with quote
general comment...
normally, you'll set a 'flag' within the ISR to tell 'main' that an 'action' has been done (if done within the ISR), or to be done by 'main'.
common practice is to just set 'flags', maybe write a byte or read 'registers' inside the ISR. Never try to do printf(...), math operations, etc. inside the ISR.
ISRs need to be small and fast! Let 'main' look at the flags and act accordingly.
hth
jay
