PS/2 keyboard driver/decoder, interrupt driven, 16F and up
Post new topic   Reply to topic    CCS Forum Index -> Code Library
stevenm86
PostPosted: Sat Jul 08, 2006 8:03 pm     Reply with quote
Hello.
I have written a nice PS/2 keyboard driver for the PIC. This reads data from a PS/2 keyboard, decodes it, and makes it available to whatever needs it. It decodes the scancodes, tracks shift and caps lock keys, and outputs pure ASCII of what is typed. The whole thing is interrupt driven so the program does not need to spend time waiting for keyboard input to happen while doing other things. Keys are read into a 16 byte circular buffer in memory which can be accessed with several simple functions.
The sendByte function was used to set the LED status on the keyboard (for caps lock) but it is currently turned off because it only worked with some of my keyboard. Some sort of timing issue? I don't know.. Whatever.
There are two pins you want from the keyboard- Clock and Data, and these are set with simple Defines. Data can be reassigned to anything, but Clock needs to be set to the External interrupt pin, which is usually B0. I know pic18 has multiple external interrupts, so you can use any one of those, assuming you also set the interrupt handler function to work on that interrupt.
The RS232 in the program is simply my debug console. You can get rid of it (as well as any printfs) if you wish.
The driver supports most basic input keys such as A-Z, 0-9, Space, and all punctuation marks. I think Escape and Backspace are also tracked. It is possible to add support for other keys pretty easily, you just need the scan code of the key. The scan code map is coded a bit weirdly, but this is mainly to make the code and tables as small as possible. Look at translate(), you will figure it out.
Functions you'll want to use-
keyhit() - tells you if there are any bytes in the buffer.
waitKey() - returns the next character in the buffer. If there is no data in the buffer, this will keep on waiting and will return whenever the next key is pressed. Shift and Caps Lock do not count, they are not considered keys that produce characters.
Again, you get back the full ASCII value of what was typed. Pressing A returns 'a', Pressing Shift+A returns 'A', pressing Capslock, Shift+A returns 'a', just like on a computer. Pressing Shift+1 returns '!'.
The program uses interrupts to read the keyboard, so as soona s a key is pressed, your code will pause running while the keyboard driver reads the incoming data. Normally this is not a problem, but if something is typed in the middle of a serial transmission, that transmission may be garbled. To fix this, simply disable interrupts during any operation that you do not want interrupted, and re-enable them after. Turning off interrupts disables the kebyoard driver, so any keys typed when they are disabled will not be processed.
I probably will not maintain this anymore, it worked well enough for me.. there may be occasional bugs, but you can fix them easily enough, and this thing works well enough anyway.
Here is the code, I hope you like it.
Steve
#include <16f877a>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT,NOPUT
#use delay(clock=4096000)
#use RS232(Baud=2400,Xmit=PIN_D2,BITS=8,INVERT)
//D0 - Clock
//D1 - Data
// Clock must be the interrupt pin
#define CLOCK PIN_B0
#define DATA  PIN_D3
unsigned char bData[16];
unsigned char idx=0;
unsigned char tmp=0;
unsigned char readByte();
unsigned char processByte();
unsigned char waitKey();
byte keyhit();
unsigned char translate(unsigned char scancode);
volatile byte shiftSet = 0;
byte kbBuffer[16];
byte kbPos = 0;
byte kbSize = 0;
byte capsSet = 0;
volatile byte extFlag = 0;
volatile byte relFlag = 0;
volatile byte key=0;
void sendByte(byte b)
    byte a=0;
    byte p = 1;
    byte t = 0;
    return;         // THIS IS NOT FULLY WORKING ON ALL KEYBOARDS
                    // SO IT IS COMMENTED OUT
                    // Some kind of timing issue or something. Whatever, they're just LEDs
    disable_interrupts(GLOBAL);
    output_low(CLOCK);
    delay_us(300);
    output_low(DATA);
    input(CLOCK);
    for(a=0; a<8; a++)
        t = b&(1<<a);
        while(input(CLOCK) == 1); //wait for 0
        output_bit(DATA, t);
        if(t)
            p++;
        while(input(CLOCK) == 0); //wait for 1
    output_bit(DATA, p&0x01);
    input(DATA);
    while(input(DATA) == 1); //wait for 0
    delay_ms(10);
    clear_interrupt(INT_EXT);
main()
    int i=0;
    unsigned char k=0;
    printf("READY >");
    output_b(0x00);
    input(CLOCK);
    ext_int_edge(H_to_L);
    enable_interrupts(INT_EXT);
        k = waitKey();
        printf("%c", k);
        while(keyhit())
            printf("%c", waitKey());
byte keyhit()
    return kbSize != 0;
    unsigned char k = 0;
    while(kbSize == 0);
    k = kbBuffer[(kbPos - kbSize)&0x0F];
    kbSize--;
    return k;
#int_ext
void kbInterrupt()
    volatile byte k=0;
    k = processByte();
    if(k != 0)
        kbBuffer[kbPos] = k;
        kbPos = ++kbPos & 0x0F;
        kbSize++;
    return;
    int i=0, t=0;
    idx=0;
    tmp=0;
    i=0;
    goto dataread;
   // while(INPUT(CLOCK) != 0);   // Wait for a keypress
            t=0;
       while(INPUT(CLOCK) != 0 && t<255)   // Wait for clock, time out if needed
           delay_us(1);
           t++;
    for(i=0; i<11; i++)
        t=0;
            delay_us(1);
            t++;
        dataread:
        bData[idx]=INPUT(DATA);
        idx++;
        if(idx==9)
            for(idx=1; idx<9; idx++)
                if(bData[idx]!=0)
                    tmp|=(1<<(idx-1));
            return tmp;
            idx=0;
            tmp=0;
     //   while(INPUT(CLOCK) == 0);
        t=0;
        while(INPUT(CLOCK) == 0 && t<255)   // Wait for clock, time out if needed
            delay_us(1);
            t++;
static const unsigned char scantableAZ[]={
0x1C, 0x32, 0x21, 0x23, 0x24, 0x2B, 0x34, 0x33, 0x43, 0x3B, 0x42, 0x4B, 0x3A, // A-Z
0x31, 0x44, 0x4D, 0x15, 0x2D, 0x1B, 0x2C, 0x3C, 0x2A, 0x1D, 0x22, 0x35, 0x1A};
// Normal numeric scancodes, starting with ',' .
static const unsigned char scantable09n[]=
0x41, 0x4E, 0x49, 0x4A, // , - . /
0x45, 0x16, 0x1E, 0x26, 0x25, 0x2E, 0x36, 0x3D, 0x3E, 0x46,     //Digits 0-9
0x00, 0x4C, 0x00, 0x55 // 0 ; 0 =
// Shift scancodes, starting at '!'
static const unsigned char scantable09s[]=
    0x16, 0x52, 0x26, 0x25, 0x2E, 0x3D, 0x00, 0x46, 0x45, 0x3E, 0x55
// Normal misc. scancode map. Scancode, ASCII value
static const unsigned char scanmapn[]=
{0x54, '[', 0x5B, ']', 0x0E, '`', 0x5D, '\\', 0x52, '\''};
// Shifted misc. scancode map. Scancode, ASCII value
static const unsigned char scanmaps[]=
{0x1E, '@', 0x36, '^', 0x4E, '_', 0x54, '{', 0x5B, '}', 0x5D, '|',
0x4C, ':', 0x41, '<', 0x49, '>', 0x4A, '?', 0x0E, '~'};
// Scancode map independent of Shift
static const unsigned char scanmapx[]=
{0x29, ' ', 0x5A, '\r', 0x0D, '\t', 0x76, 27, 0x66, 0x08};
// Extended scancode map
static const unsigned char scanmape[]=
0x71, 0x7F
    int i=0;
    if(extFlag == 0)
        for(i=0; i<10; i+=2)
            if(scanmapx[i] == scancode)
                return scanmapx[i+1];
        for(i=0; i<26; i++)
            if(scantableAZ[i] == scancode)
                if(shiftSet ^ capsSet)
                    return i+65;
                    return i+65 + 32;
        if(shiftSet)
            for(i=0; i<11; i++)
                if(scantable09s[i] == scancode)
                    return i+'!';
            for(i=0; i<22; i+=2)
                if(scanmaps[i] == scancode)
                    return scanmaps[i+1];
        } else
            for(i=0; i<18; i++)
                if(scantable09n[i] == scancode)
                    return i+',';
                if(scanmapn[i] == scancode)
                    return scanmapn[i+1];
    } else      // Extended keys
        for(i=0; i<2; i+=2)
            if(scanmape[i] == scancode)
                return scanmape[i+1];
    return '?';
    unsigned char i, j;
    i = readByte();
    if(i == 0xF0)       //A key is being released
        relFlag = 1;
        return 0;
    if(i == 0xE0)       // Extended key operation
        extFlag = 1;
        relFlag = 0;    //0xE0 always first in sequence, OK to clear this
        return 0;
    if(relFlag == 0)    // Pressing a key
        if(extFlag == 0)    // Non-extended key pressed
            if(i == 0x12 || i == 0x59)
                shiftSet = 1;
                return 0;
            if(i == 0x58)
                sendByte(0xED);
                if(capsSet == 0)
                    capsSet = 1;
                    sendByte(0x04);
                } else
                    capsSet = 0;
                    sendByte(0x00);
                return 0;
        j = translate(i);
        extFlag = 0;
        return j;
    if(relFlag == 1)    //Releasing a key
        relFlag = 0;    //If a flag was set but not handled, we wouldn't have gotten here
        extFlag = 0;    //OK to clear this here
        if(extFlag == 0)   // Releasing a nonextended key
                shiftSet = 0;
                return 0;
//        } else              // Releasing an extended key
//            return 0;
//        return 0;
    return 0;
[/code]
tranhuyky
Please help me, turn on Numlock led
PostPosted: Mon Dec 25, 2006 7:35 am     Reply with quote
I connect a PS/2 Keyboard (Mitsumi) with PIC 16F877A. I want to turn on Numlock led, but i can't. i try many way but now is not Ok. Anyone else did it, Would you please help me.
foodwatch
Keyboard program
PostPosted: Sun Jan 14, 2007 7:40 pm     Reply with quote
Steve,I tried your program on an 18f4550 and it works fine. In my project I need to read a stand alone numeric keypad. I am a C novice and am having trouble figuring out how to modify/add the scan table to allow numeric keypad scan codes. I dont need any of the codes for a full keyboard. Thanks
smtpl04
ps/2 keyboard driver
PostPosted: Thu Apr 19, 2007 7:30 am     Reply with quote
I have tried your code & its working best for keyboard to PIC transfer. But not for PIC to keyboard transfer. I have modified your void sendByte(byte b) code(given below) for PIC to keyboard transfer & its working ok. Try it in your project & reply me.
Also I need another code for PIC to PC communication through ps/2 port. Please help me for this.
Thanks,
Sardar Patil.
    byte a=0;
    byte p = 0;
    boolean t = 0;
  //  return;         // THIS IS NOT FULLY WORKING ON ALL KEYBOARDS
    output_low(KEYCLK);
    delay_us(80);
  //  input(KEYCLK);
    output_low(KEYDATA);
    output_high(KEYCLK);
    input(KEYCLK);
    for(a=0; a<8; a++)
        while(input(KEYCLK) == 1); //wait for 0
        t = bit_test(b,a);
        output_bit(KEYDATA, t);
        if(t)
            p++;
        while(input(KEYCLK) == 0); //wait for 1
    t = bit_test(p,0);
        t = ~t;
     output_bit(KEYDATA, t);   // input(KEYDATA);
  ///  while(input(KEYCLK) == 0); //wait for 1
     output_float(KEYDATA);
[/quote]
sardar
3dfx
PostPosted: Sat May 12, 2007 5:04 am     Reply with quote
i have tested this code but i couldnt get any response from keyboard.is there any thing wrong?
Celso Missias
PostPosted: Wed Oct 24, 2007 6:40 am     Reply with quote
Hi Steve
Thanks for the code,
After each key pressed a '?' is sended via serial too after the letter pressed.
So, when I press 'a', I receive 'a?',
'b', 'b?' and so on...
Why it is happening?
Dimlow
Parity bit
PostPosted: Tue Sep 30, 2008 10:44 am     Reply with quote
I think the parity bit in the send byte is wrong. Your Sending and even parity, not and odd parity!!! Probably why it don't work on all keyboards
should read
output_bit(DATA, p&0x10);
abo_shreek11
Re: Keyboard program
PostPosted: Thu Nov 27, 2008 8:48 am     Reply with quote
May you tell me how much resistance is the pull-up resistor you used ? I have 18f4550 too, and when I press a button on key board it shows with some "?" character on the lcd. I have a doubt in the pull-up resistor I am using.
ThePraiodanish
PostPosted: Sat Mar 06, 2010 7:36 am     Reply with quote
Hi all,
you can get rid of the "?" after each key pressed by replacing the line
return '?';
with
return 0x00;
in the function unsigned char translate(unsigned char scancode).
Although the code works great for me I have one problem:
For debugging purposes I print the received scancode to the rs232 port within the interrupt routine, the reading and printing of the circular buffer is disabled.
However if I write
    //printKey();
   //for(i=0 ; i < 10000 ; i++);
   delay_ms(1);
in the main() - function the scancodes returned are garbage!
It seems as if the delay-routine wasn't interrupted by the interrupt properly.
At first I thought it's due to the time the delay needs to finish the statement which is in progress before jumping to the interrupt handler but I saw that the author runs this code at 4 MHz clock which means there are about 40 cycyles between each interrupt. I'm running the code at 11,0592 MHz (=110 cycles between each interrupt) so there should be plenty time for jumping to the interrupt handler. Any Ideas?
Thanks a lot,
Thomas
PostPosted: Sun Mar 07, 2010 1:53 am     Reply with quote
Ask your question in the General Discussion forum. You'll get far
better exposure there, and your problem is likely related to general
programming issues, and not specifically to this PS/2 driver.
guntor
PS2 Keyboard emulator v.1.0.0 alpha
PostPosted: Tue Aug 10, 2010 3:27 pm     Reply with quote
Maybe someone need a PS2 Keyboard emulator
#include <12F675.h>
#fuses INTRC_IO,NOWDT,NOMCLR,NOPROTECT
#use rs232(baud=9600,parity=N,xmit=PIN_A0,rcv=PIN_A1,bits=8,STREAM=DEBUG)
#use rs232(baud=9600,parity=N,xmit=PIN_A3,rcv=PIN_A2,bits=8,STREAM=RFID)
//#define DEBUGLONG
//#define DEBUGSHORT
#define KEYCLK PIN_A5
#define KEYDATA  PIN_A4
typedef unsigned char uchar;
typedef boolean bit;
                                      [+5V] VDD -|1   8|- VSS [GND]
   [KEYCLK] (with Pullup) GP5/T1CKI/OSC1/CLKIN  -|2   7|- GP0/AN0/CIN+/ICSPDAT [XMIT DEBUG]
[KEYDATA] (with Pullup) GP4/AN3/T1G/OSC2/CLKOUT -|3   6|- GP1/AN1/CIN-/VREF/ICSPCLK [RCV DEBUG]
                                   GP3/MCLR/VPP -|4   5|- GP2/AN2/T0CKI/INT/COU
// A-Z, völlig willkürliche anordnung...
// http://www.computer-engineering.org/ps2keyboard/scancodes2.html
// Für break Code: vorher 0xF0 senden, dann wieder Code
const uchar t_a_z[26]={0x1C,0x32,0x21,0x23,0x24,0x2B,0x34,0x33,0x43,0x3B,0x42,0x4B,0x3A,0x31,0x44,0x4D,0x15,0x2D,0x1B,0x2C,0x3C,0x2A,0x1D,0x22,0x35,0x1A};
// 0-9, völlig willkürliche anordnung...
const uchar t_0_9[26]={0x45,0x16,0x1E,0x26,0x25,0x2E,0x36,0x3D,0x3E,0x46};
// ASCII translatedtoScantable
uchar atrsc[2];
uchar lastbyte;
void sendNibble(boolean t);
bit getNibble();
void sendByte(byte sendbyte);
uchar receiveByte();
void senduchar(uchar sendb) ;
void translateASCIItoScanTable(uchar ASCII,uchar extended);
void sendString(uchar* str);
// SetBit: Einzelnes Bit senden...
//      10 w 30    40
void sendBit(boolean t){
   delay_us(10);//15
   output_bit(KEYDATA,t);
   delay_us(30);    //20
   output_low(KEYCLK);
   delay_us(40);        //40
// getBit: Einzelnes Bit empfangen...
//         40    15 r 20
bit getBit(){
   bit t;
   output_low(KEYCLK);
   delay_us(40);
   delay_us(15);
   t=input(KEYDATA);
   delay_us(20);
   return t;
void sendByte(byte sendbyte){
   uchar i;
   byte parity = 0;
   bit t = 0;
   // ausgangslage
   // Delay, falks mehrere Bytes hintereinander gesendet werden...
   delay_us(250);
   // startbit
   sendBit(0);
   for(i=0;i<8;i++){
      t=bit_test(sendbyte,i);
      if(t)parity++;
      sendBit(t);
   // Parity Bit
   t=~bit_test(parity,0);
   sendBit(t);
   // Stop bit
   sendBit(0);
   lastbyte=sendbyte;
   input(KEYCLK);
   input(KEYDATA);
uchar receiveByte(){
   uchar empf;
   uchar parity;
   uchar i;
   bit t;
   bit stopbit;
   // ignore startbit???
   // Generate Clock and receive bits.. LSB first...
   for(i=7;i!=0;i--){
      t=getBit();
      if(t){
         parity++;
         empf|=t<<i;
   // parity bit...
   t=getBit();
   // stop bit...
   stopbit=getBit();
   if(stopbit!=1){
      #ifdef  DEBUGLONG
         fprintf(DEBUG,"Falsches Stopbit");
      #ifdef  DEBUGSHORT
         fprintf(DEBUG,"fsb");
   // ACK senden...
   delay_us(10);
   delay_us(25);
   output_low(KEYCLK);
   delay_us(40);
   if(t!=~bit_test(parity,0)){
      #ifdef  DEBUGLONG
         fprintf(DEBUG,"Haha, partity falsch");
      #ifdef  DEBUGSHORT
         fprintf(DEBUG,"fp");
   #ifdef  DEBUGLONG
      fprintf(DEBUG,"empfanges byte %x",empf);
   #ifdef  DEBUGSHORT
      fprintf(DEBUG,"eb %x",empf);
   return empf;
void senduchar(uchar sendb) {
   uchar empf;
   unsigned int16 breaker;
//Summary: Bus States
//Data = high, Clock = high:  Idle state.
//Data = high, Clock = low:  Communication Inhibited.
//Data = low, Clock = high:  Host Request-to-Send
   while(true){
      // Host will was...
      if(input(KEYCLK)==0 && input(KEYDATA)==1){
         #ifdef  DEBUGLONG
            fprintf(DEBUG,"dammed, not free");
         #ifdef  DEBUGSHORT
            fprintf(DEBUG,"nf");
         // 50ms zeit, um Data low zu ziehen und Clock auf high
         // Dann dürfen wir Clock spielen und nibbles empfangen...
         breaker=0;while(input(KEYDATA)==1&&input(KEYCLK)==0&&breaker<0xFFFFF)breaker++; // Wait for 0
         breaker=0;while(input(KEYCLK)==0&&breaker<0xFFFFF)breaker++; // Wait for 0
         #ifdef  DEBUGLONG
            fprintf(DEBUG,"ready to receive");
         #ifdef  DEBUGSHORT
            fprintf(DEBUG,"rr");
         // receive Byte
         empf=receiveByte();
         #ifdef  DEBUGLONG
         #ifdef  DEBUGSHORT
         // Reset Keyboard (Too fast, false parity etc...)
         if(empf==0xFF){
            // Acknowledge
            sendbyte(0xFA);
            // BAT erfolgreich...
            sendbyte(0xAA);
            #ifdef  DEBUGLONG
               fprintf(DEBUG,"Bytes sent.");
            #ifdef  DEBUGSHORT
               fprintf(DEBUG,"bs");
         // Resend last byte...
         }else if(empf==0xFE){
              sendbyte(lastbyte);
      // Wenn Frei (CLK = HIGH),
      // Schauen, ob nach 50us immer noch frei, dann frei zur verwendung...
      }else{
         delay_us(50);
         if(input(KEYCLK)==1){
   #ifdef  DEBUGLONG
         fprintf(DEBUG,"yeah, free");
   #ifdef  DEBUGSHORT
         fprintf(DEBUG,"f");
   // Todo: special caracters
   translateASCIItoScanTable(sendb,0x00);
   // Todo: uppercase
   if(atrsc[1]!=0x00){
       sendbyte(atrsc[1]);
   // Send Make Key...
   sendbyte(atrsc[0]);
   // Ssend Break Key...
   sendbyte(0xF0);
   sendbyte(atrsc[0]);
   if(atrsc[1]!=0x00){
      sendbyte(0xF0);
      sendbyte(atrsc[1]);
   // Not too many keys per second
   delay_ms(20);
void translateASCIItoScanTable(uchar ASCII,uchar extended){
   if(ASCII>='A' && ASCII<='Z'){
      atrsc[0]=t_a_z[ASCII-'A'];
      atrsc[1]=0x12;
   }else if(ASCII>='a' && ASCII<='z'){
      atrsc[0]=t_a_z[ASCII-'a'];
      atrsc[1]=0x00;
   }else if(ASCII>='0' && ASCII<='9'){
      atrsc[0]=t_0_9[ASCII-'0'];
      atrsc[1]=0x00;
   // Rest of Translation Table
   // layout spefific!!
   // layout: http://upload.wikimedia.org/wikipedia/commons/2/22/KB_US-International.svg
   }else if(ASCII>=' ' && ASCII<=' '){
      //atrsc[0]=t_a_z[ASCII-'A'];
      atrsc[0]=0x29;
      atrsc[1]=0x00;
void sendString(uchar* str){
   while(*str!=0x00){
      senduchar(*str);
      str++;
   while(TRUE){
      strcpy(RFID_rec.data,"ABCDE532d");
      sendString(RFID_rec.data);
      delay_ms(2500);
Tufican
doesn't work :(((
PostPosted: Mon Sep 19, 2011 12:54 pm     Reply with quote
hi everybody i have a problem
i m using ccs c canbus kit pic18f4580
i wrote and add this lines to ps2 code
#include <18f4580.h>
#use delay(clock=20000000)  // my clock frequency
//my baud rate and rs 232 pins. serial is working fine..
#define Clock pin_d0
#define Data pin_d1
main();
set_tris_d(0b00000011); //  i am using my free pins d0 and d1 for input?
Where is my wrong please help me :( i m going crazy :((
i have a pc oscilloscope and when i push the button i can see clock and data
keyboard is working.
have a good day to everybody
the total code is here.
#define Data pin_d1
//D0 - Clock
//D1 - Data
byte keyhit();
byte kbBuffer[16];
byte kbPos = 0;
byte kbSize = 0;
byte capsSet = 0;
    byte a=0;
    byte p = 1;
    byte t = 0;
    output_low(CLOCK);
    delay_us(300);
    output_low(DATA);
    input(CLOCK);
    for(a=0; a<8; a++)
        t = b&(1<<a);
        if(t)
            p++;
    input(DATA);
    delay_ms(10);
main()
    int i=0;
    unsigned char k=0;
    printf("READY >");
    output_b(0x00);
    input(CLOCK);
set_tris_d(0b00000011);    // RA0 ucu giriş olarak ayarlandı.
        k = waitKey();
        printf("%c", k);
        while(keyhit())
byte keyhit()
    return kbSize != 0;
    while(kbSize == 0);
    kbSize--;
    return k;
#int_ext
void kbInterrupt()
    volatile byte k=0;
    k = processByte();
    if(k != 0)
        kbSize++;
    return;
    int i=0, t=0;
    idx=0;
    tmp=0;
    i=0;
    goto dataread;
            t=0;
           delay_us(1);
           t++;
    for(i=0; i<11; i++)
        t=0;
            delay_us(1);
            t++;
        dataread:
        idx++;
        if(idx==9)
                if(bData[idx]!=0)
                    tmp|=(1<<(idx-1));
            return tmp;
            idx=0;
            tmp=0;
        t=0;
            delay_us(1);
            t++;
0x71, 0x7F
    int i=0;
    if(extFlag == 0)
        for(i=0; i<26; i++)
                    return i+65;
                    return i+65 + 32;
        if(shiftSet)
            for(i=0; i<11; i++)
                    return i+'!';
        } else
            for(i=0; i<18; i++)
                    return i+',';
        for(i=0; i<2; i+=2)
    return '?';
    unsigned char i, j;
    i = readByte();
        relFlag = 1;
        return 0;
        extFlag = 1;
        return 0;
                shiftSet = 1;
                return 0;
            if(i == 0x58)
                sendByte(0xED);
                if(capsSet == 0)
                    capsSet = 1;
                    sendByte(0x04);
                } else
                    capsSet = 0;
                    sendByte(0x00);
                return 0;
        j = translate(i);
        extFlag = 0;
        return j;
                shiftSet = 0;
                return 0;
//            return 0;
//        return 0;
    return 0;
pocanada
Reading keyboard PS/2 bytes
PostPosted: Mon Feb 04, 2013 6:32 pm     Reply with quote
Here is example of code I used to decode the PS/2 bytes. I used a PIC18F4550 with CLOCK = PIN_B1(Int1) and DATA = PIN_D4. It seemed to work better when I read all the bytes first rather than one at a time before decoding.
//----------------------- PS2_Keyboard -----------------------------
#include "18F4550.h"
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#use rs232(baud=19200,xmit=PIN_C6,rcv=PIN_C7,stream=prime)
//----------  PIC 18F4550 board stuff ------------------------------
#use fast_IO(B)
#use fast_IO(D)
#define led_on output_high(PIN_D3)
#define led_off output_high(PIN_D3)
#define y_led_on; output_low(PIN_D7)
#define y_led_off; output_high(PIN_D7)
#define g_led_on; output_low(PIN_D5)
#define g_led_off; output_high(PIN_D5)
#define but PIN_B4
#define but PIN_B4
//-------- Rotary Switch Stuff  A is the interrupt2 pin  ------------
#define A PIN_B2
#define B PIN_D6
#define PB PIN_D4
//------  PS2 Keyboard stuff---- Clock must be the interrupt1 pin ---
#define CLOCK PIN_B1
#define DATA  PIN_D1
#define hi_clk_delay;  t=0;while(input(CLOCK)==1 && t<255){delay_us(1);t++;}
#define lo_clk_delay;  t=0;while(input(CLOCK)==0 && t<255){delay_us(1);t++;}
int8 readabyte(void);
int8 processByte(void;
int8 translate(int1 shft,int8 scancode);
int8 t;
int8 bData[16];
//------------------ scan codes --------------------------------------------
const int8 scan_byte[]={
0x31, 0x44, 0x4D, 0x15, 0x2D, 0x1B, 0x2C, 0x3C, 0x2A, 0x1D, 0x22, 0x35, 0x1A,
0x45, 0x16, 0x1E, 0x26, 0x25, 0x2E, 0x36, 0x3D, 0x3E, 0x46, 0x0E, 0x4E ,0x55,
0x5D, 0x29, 0x54, 0x5B, 0x4C, 0x52, 0x41, 0x49, 0x4A};
//------------------ upper case literals -----------------------------------
const int8 upper_char[]={
'A',  'B',  'C',  'D',  'E',  'F',  'G',  'H',  'I',  'J',  'K',  'L',  'M',
'N',  'O',  'P',  'Q',  'R',  'S',  'T',  'U',  'V',  'W',  'X',  'Y',  'Z',
')',  '!',  '@',  '#',  '$',  '%',  '^',  '&',  '*',  '(',  '~',  '_',  '+',
//------------------ lower case literals ----------------------------------
const int8 lower_char[]={
'a',  'b',  'c',  'd',  'e',  'f',  'g',  'h',  'i',  'j',  'k',  'l',  'm',
'n',  'o',  'p',  'q',  'r',  's',  't',  'u',  'v',  'w',  'x',  'y',  'z',
'0',  '1',  '2',  '3',  '4',  '5',  '6',  '7',  '8',  '9',  '`',  '-',  '=',
#int_ext1
void kbInterrupt() {
int8 c=0;
   disable_interrupts(INT_EXT1_H2L);
   c = processByte();
   if(c !='?')
      fprintf(prime,"%c",c);
   enable_interrupts(INT_EXT1_H2L);
}   //kbInterrupt()
main(){
 set_tris_b(0xFF);
 set_tris_d(0x5F);
 port_b_pullups(0xFF);
    fprintf(prime,"PS2_Keyboard - January 31, 2013\r\n");
    while(1){
   }    //while(1)
}    //main
//--------------------  my readabyte() -----------------
int1 readabyte(void){
int8 i=0;
int8 n=0;
int8 bPar=0;
int8 tmp=0;
int1 enough=0;
      for(i=0;i<16;i++)
           bData[i]=0;
        while(input(CLOCK)==0);         //start pulse
      do{
         for(i=0;i<8;i++){             // following 8 pulses
            hi_clk_delay;
            shift_right(&bData[n],1,input(DATA));
            lo_clk_delay;
         }   //for i<8
         for(i=0;i<2;i++){             // parity and stop pulse
            hi_clk_delay;
            shift_right(&bPar,1,input(DATA));
            lo_clk_delay;
         }   //for i<2
         tmp++;
         hi_clk_delay;         // Inner pulses delay
         if(input(CLOCK)== 1)      // if after this clock still high ==  end
            enough = 1;
         else{
            n++;
            lo_clk_delay;         //start pulse delay
         }   //else
      }while((n < 16) && !enough);   //do
              return(tmp);
}   //readabyte()
//-----------------------  my process byte  ----------
int8 processByte(void){
int8 k=0;
int8 j=0;
static int1 shift,caplock;
   k = readabyte();      //k = # bytes in bData array;
#ifdef PRINT_DATA
   int8 i;
   fprintf(prime,"%U:  ",k);
   for(i=0;i<k;i++)
       fprintf(prime,"%X  ",bData[i]);
    fprintf(prime,"\r\n");
 //Look for cap locks first
    if((bData[0]==0x58)&&(!caplock)){
       shift=1;
       caplock=1;
    }   //if...
   else if((bData[0]==0x58)&&(caplock)){
      shift=0;
      caplock=0;
   }   //else if...
 //Then Look for L Shift or R Shift keys
     if((bData[0]==0x12)||(bData[0]==0x59))
       shift = 1;
    else{
       if(((bData[0]==0xF0)&&(bData[1]==0x12)||
       (bData[0]==0xF0)&&(bData[1]==0x59))&& !caplock)
          shift = 0;
    }   //else...
    j = translate(shift,bData[0]);    //"j" = int8 of the character returned
   return(j);
}   //processByte()
//------------------  my translate  -----------------------------
int8 translate(int1 shft,int8 scancode){
int8   i;
   if(shft){
      for(i=0; i<52; i++){
      if(scan_byte[i] == scancode)
         return(upper_char[i]);
      }   //for(i=...
   }   //shft
   else{
         return(lower_char[i]);
      }   //for(i=...
   }   //!shft
     return('?');
}   //translate()
mariano
Re: PS/2 keyboard driver/decoder, interrupt driven, 16F and
PostPosted: Sun Oct 06, 2013 9:50 am     Reply with quote
stevenm86 Hello.
Hey proven soft and the problem I had is that when you press the number buttons works well then pressing the shift key changes to the symbols even hi all well but when they press the shift key does not return to the numbers remaining in the Symbols could help me, thanks my name is Mariano and my email marianoarias1967@yahoo.com.ar
kalyan
PostPosted: Sat Jun 07, 2014 9:23 am     Reply with quote
mariano wrote:
stevenm86 Hello.
even i am facing the same problem kindly help
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
