Good morning, I'm trying to use the debugger to the ICD3 Pic12F615 and AC162083 adapter but I get compile error: "Selected Parts ICD does not have debugging capability."
How can I fix it?
Posted: Fri Sep 16, 2011 4:23 am
You need the chip with the extra debug pins. The 12F616-ICD. The standard 12F615, doesn't have the debug connections.
There should be a table explaining this in the data for your header, and it is also mentioned in the chip's own data sheet.
Kevin34
Posted: Tue Sep 20, 2011 3:24 am
AC162083 I have the adapter in position 9 but it is a compilation error, not ICD3. Use # device ICD = TRUE and the error is on this line (Selected Parts ICD debugging does not have capability.)
Can not debug because it is not supported by Pic12F615?
