ktallevi
Posted: Thu Jul 22, 2010 6:24 pm |
Has anyone modified this to count milliseconds as well?
thanks |
princejude
Posted: Wed Aug 11, 2010 7:08 am |
Hello everyone, I am a student and new in CCS and C language in general. I have worked with PIC MCUs using ASSEMBLY LANGUAGE. My School project is to design and construct a DIGITAL CLOCK using PIC MCU. I modified (Mr/Engr...) ckielstra's"Timer based Real Time Clock (RTC)" code posted since Tue Feb 28, 2006 shown below to get a digital clock. The digital clock worked on proteus but the problem I have is that the first three digits are flashing ON and OFF(though there timing is correct). It is only the last digit that is permanent ON.
PLSSSSS how will I make the four digits to be ON instead of flashing ?
I will also be happy if anyone can give me materials or links on how to learn CCS (PIC C).
Here is the code posted by ckielstra
// Zero Drift Real Time Clock
// Original code supplied by Neutone.
// Some small optimizations by C.Kielstra.
#include <18F458.h>
#fuses HS,NOWDT,NOLVP
//RTC variables
#define XTAL_FREQUENCY 20000000
#define TIMER1_FREQUENCY (XTAL_FREQUENCY / 4) // 1 clock tick = 1 instr. cycle = crystal frequency / 4
int32 Ticker;
int8 Seconds=0;
//optional:
// int8 Year=0,Month=0,Days=0,Hours=0,Minutes=0;
// Test whether a given year is a leap year.
// This optimized version only works for the period 2001 - 2099
#define IS_LEAP(year) (year%4 == 0)
// Initialize RTC
void Initialize_RTC(void)
Ticker = TIMER1_FREQUENCY; // initialize clock counter to number of clocks per second
setup_timer_1( T1_INTERNAL | T1_DIV_BY_1 ); // initialize 16-bit Timer1 to interrupt
// exactly every 65536 clock cycles
// (about 76 times per second)
enable_interrupts( INT_TIMER1 ); // Start RTC
// -=Process Zero Drift Real Time Clock Information=-
// Most algorithms configure the timer to generate an interrupt every 100ms, and
// then count the number of interrupts. The problem in that approach is that most
// clock frequencies can't be divided by 256 and you don't get an exact 100ms.
// The small errors will add up to an error of several seconds a day.
// The algorithm presented here is exact in the long run because it doesn't
// count the number of interrupts but counts the number of clock cycles.
#int_TIMER1
void TIMER1_isr()
Ticker -= 65536; // Decrement ticker by clocks per interrupt
if ( Ticker < 65536 ) // If second has expired
{ Ticker += TIMER1_FREQUENCY; // Increment ticker by clocks per second
seconds++; // Increment number of seconds
/* --- Optional part start ---
if(Seconds == 60) {Minutes++; Seconds=0;
if(Minutes == 60) {Hours++; Minutes=0;
if(Hours == 24) {Days++; Hours=0;
if ( (Days == 29 && Month==2 && !IS_LEAP(Year))
|| (Days == 30 && Month==2)
|| (Days == 31 && (Month==4 || Month==6 || Month==9 || Month==11 ))
|| (Days == 32)
) {Month++;Days=0;}
if(Month == 13) {Year++; Month=0;}
--- Optional part end --- */
// Example program for using the RTC
int8 prev_second;
Initialize_RTC();
enable_interrupts( GLOBAL );
// loop forever
// Toggle output every second
if (seconds != prev_second)
prev_second = seconds;
output_toggle(PIN_A1);
HERE IS MY MODIFIED CODE
I changed the crystal value to 25MHz (instead of 20MHz) because i did not see 20MHz in our market. Will this different crystal value affect the timing? Is my one second timing still correct?
#include <16F887.h>
#use delay(clock=25000000)
#FUSES PUT //No Power Up Timer
//RTC variables
#define XTAL_FREQUENCY 25000000
int32 Ticker;
int8 Seconds=0;
//optional:
// Initialize RTC
int decode(int8 Minutes)
int code;
switch(Minutes)
case 0: code = 0x40;break;
case 1: code = 0x79;break;
case 2: code = 0x24;break;
case 3: code = 0x30;break;
case 4: code = 0x19;break;
case 5: code = 0x12;break;
case 6: code = 0x02;break;
case 7: code = 0x78;break;
case 8: code = 0x00;break;
case 9: code = 0x10;break;
return code;
int8 prev_second;
int Sec_units, Min_units, Sec_tens, Min_tens;
int Result;
set_tris_b(0x00);
set_tris_a(0x00);
Initialize_RTC();
// loop forever
Sec_tens = Seconds/10;
Sec_units= Seconds%10;
Min_tens = Minutes/10;
Min_units= Minutes%10;
output_A(0x02);
Result = decode(Min_tens);
output_C(Result);
delay_ms(10);
output_A(0x01);
Result = decode(Min_units);
output_C(Result);
delay_ms(10);
output_A(0x08);
Result = decode(Sec_tens);
output_C(Result);
delay_ms(10);
output_A(0x04);
Result = decode(Sec_units);
output_C(Result);
delay_ms(10);
#int_TIMER1
void TIMER1_isr()
// --- Optional part start ---
|| (Days == 32)
) {Month++;Days=0;}
// --- Optional part end ---
andrewg
Joined: 17 Aug 2005 Posts: 162 Location: Perth, Western Australia
Posted: Fri Aug 13, 2010 9:43 pm |
The reason your display is flickering is because you're only updating it when the seconds change. You need to update it all the time.
| Quote: | | I changed the crystal value to 25MHz |
Check the PIC datasheet. You'll find the maximum oscillator frequency (table 17-1) is 20MHz. While you're probably OK (PICs are pretty tough), you really should use a slower crystal. _________________ Andrew |
princejude
Posted: Tue Aug 17, 2010 7:15 am |
Thanks Mr Andrew, I have edited the code as follows:
1. I changed the crystal value to 4MHz.
| Code: | #use delay(clock=25000000) to #use delay(clock=4000000)
and #define XTAL_FREQUENCY 25000000 to #define XTAL_FREQUENCY 4000000 |
2. I also changed the switch variable from Minutes to Seconds
| Code: | | switch(Minutes) to switch(Seconds) |
3. I reduced the "delay_ms(10);" from 10ms to 1ms
| Code: | | delay_ms(10); to delay_ms(1); |
After all these changes the FLICKERING/FLASHING/BLINKING STOPPED
I AM STILL WORKING ON THE TIME SETTING FUNCTIONS (need help if any).
I will like to use 4 push button switches labeled SET,MODE,UP and DOWN
The expected operation is as follows:
If i press the SET button - the clock will display the current time, call the MODE function(by default the MODE function will select SET_Min function) and wait for the next button to be pressed.
If i press the MODE button - it will select SET_Hr function
When the SET_Min function is selected - if i press UP button the Minutes value will increase and if i press DOWN the Minutes value will decrease.
When the SET_Hr function is selected - if i press UP button the Hours value will increase and if i press DOWN the Hours value will decrease.
Pls i need some advice (or help) on how to achieve these.
HERE IS MY CODE (the time setting section is not yet complete)
| Code: | #include <16F887.h>
#FUSES XT //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#define D 1
#define SET PIN_D0
#define MODE PIN_D1
#define UP PIN_D2
#define DOWN PIN_D3
int32 Ticker;
int8 Seconds=0;
// int1 flg=false;
// Initialize RTC
enable_interrupts(INT_TIMER1); // Start RTC
// Set Time
void set_Hr()
if(!input(UP)) {enable_interrupts(INT_TIMER1); Seconds++;}
else if(!input(DOWN)) {enable_interrupts(INT_TIMER1); Seconds--;}
void set_Min()
// Main Program Start Here
int decode(int8 Seconds)
int code;
switch(Seconds)
return code;
int8 prev_second;
int Sec_units, Min_units, Sec_tens, Min_tens, Hr_units, Hr_tens;
int Result;
Initialize_RTC();
while(true)
if(!input(SET)) {disable_interrupts(INT_TIMER1); SET_Hr();}
{ prev_second = seconds; }
Hr_tens = Hours/10;
Hr_units= Hours%10;
output_A(0x20);
Result = decode(Hr_tens);
output_C(Result);
delay_ms(D);
output_A(0x10);
Result = decode(Hr_units);
output_C(Result);
delay_ms(D);
output_A(0x02);
output_C(Result);
delay_ms(D);
output_A(0x01);
output_C(Result);
delay_ms(D);
output_A(0x08);
output_C(Result);
delay_ms(D);
output_A(0x04);
output_C(Result);
delay_ms(D);
// set_Hr();
#int_TIMER1
void TIMER1_isr()
if(Seconds == 60)
if(Minutes == 60)
Hours++; Minutes=0;
if(Hours == 24)
Days++; Hours=0;
if((Days == 29 && Month==2 && !IS_LEAP(Year))|| (Days == 30 && Month==2)
|| (Days == 31 && (Month==4 || Month==6 || Month==9 || Month==11 ))||(Days == 32))
{Month++;Days=0;}
if(Month == 13)
{Year++; Month=0;}
| [/b] |
andrewg
Posted: Tue Aug 17, 2010 8:26 am |
It's good to hear your display is working now.
Do you have any specific questions about handling your input switches? I suggest that you Google "switch debouncing" and have a read. _________________ Andrew |
