c_user
Pointer to array pointer to structures - compile error help |
Posted: Sat Jun 12, 2010 3:55 pm |
I have the following structure:
Code: | typedef struct font_struct
int16 font_length;
int16 font_width;
} font_select; |
I then add an array of pointers to this structure, which compiles correctly:
Code: | font_select *screen_ptr[3]; |
Now, I want to add a point to this array of pointers, and am using the following construction:
Code: | font_select (*(*scr_ptr)[]); |
The compiler issues an error report:
Code: | Executing: "C:\Program Files\PICC\Ccsc.exe" +FH "FT430.c" +DF +LN +T +A +M +Z +Y=9 +EA
*** Error 58 "FT430.c" Line 72(17,18): Expecting a close paren
*** Error 43 "FT430.c" Line 72(19,20): Expecting a declaration
*** Error 48 "FT430.c" Line 72(21,28): Expecting a (
*** Error 43 "FT430.c" Line 72(29,30): Expecting a declaration
*** Error 43 "FT430.c" Line 72(30,31): Expecting a declaration
*** Error 43 "FT430.c" Line 72(31,32): Expecting a declaration
*** Error 12 "FT430.c" Line 79(10,17): Undefined identifier scr_ptr
7 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Sat Jun 12 14:41:59 2010 |
What am I doing wrong? |
Posted: Sat Jun 12, 2010 11:40 pm |
The method used in the test program shown below appears to work.
Here's the program output (in MPLAB simulator):
Quote: |
Pointers to structures:
0005
0009
000d
Pointer to array of pointers:
0011
.Sym file:
Quote: |
005-010 fs
011-016 screen_ptr
017-018 scr_ptr
Test program. Compiled with vs. 4.107:
#include <18F452.h>
int16 font_length;
int16 font_width;
}font_select, *p_fs;
// Declare an array of 3 of the above structures.
font_select fs[3];
// Declare an array of pointers to the 3 structures,
// and initialize it the start address of each
// structure.
p_fs screen_ptr[3] = {
&fs[0].font_length,
&fs[1].font_length,
&fs[2].font_length
// Declare a pointer to the array of pointers above
// and initialize it.
p_fs *scr_ptr = screen_ptr;
int8 i;
printf("Pointers to structures: \r");
for(i=0; i < 3; i++)
printf("%lx \r", (int16)screen_ptr[i]);
printf("Pointer to array of pointers: \r");
printf("%lx \r", (int16)scr_ptr);
c_user
Posted: Sun Jun 13, 2010 10:48 pm |
Thanks for giving me a solution. I see why it works. But I am still curious whether my C declaration was wrong, or whether the compiler can't handle it. If you know, I'd appreciate hearing your analysis. |
