kiewic
Making USB And Serial Work Together [solved] |
Posted: Sun May 16, 2010 11:03 am |
Hello. I have a PIC 18F2550 running with a 20MHz crystal and the following configuration.
Code: | #include <18F2550.h>
#device adc=8
#FUSES HSPLL //Internal RC Osc INTRC
#FUSES BROWNOUT //No brownout reset NOBROWNOUT
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //No Power Up Timer NOPUT
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES NOXINST //Extended set extension and Indexed Addressing mode disabled (Legacy mode) NOXINST
#FUSES PLL5 //Divide By 12(48MHz oscillator input) PLL12
#FUSES CPUDIV1 //System Clock by 4 CPUDIV4
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES VREGEN //USB voltage regulator enabled
#use delay(clock=48000000) |
Now, I need to read information from a serial RFID reader. It works at 2400 bps.
I have the following configuration for the serial communication, but it is reading garbage.
Code: | #use rs232(baud=2400, rcv=PIN_A0, ENABLE=PIN_A1, stream=RFID, PARITY=N, bits=8) |
I have also tried with other baud values, like 12000, 480, 4800, 1200, 6000 and 960. But nothing works.
