Now trying to get tinybld to bootload at 19200 and use terminal at 9600.
currently it takes the downloader baud rate for terminal rate, may be able to edit the config file to do it, more investigating required.
Rohit de Sa
Posted: Tue May 04, 2010 10:53 am
Ok, I haven't really understood what the problem is. Anyway, the bootloader defaults to 115200 baud. If you want other speeds you'll have to re build the asm file.
