DS18B20
DS18B20
PostPosted: Tue Apr 28, 2009 8:35 am     Reply with quote
I have a problem about ds18b20 digital termometer. I found a driver for it on internet. And I wrote a simple code for it.
1wire.c
#ifndef ONE_WIRE_C
#define ONE_WIRE_C
 * One wire (1-wire) driver for CCS C compiler. Suitable for use with devices
 * such as the DS18B20 1-wire digital temperature sensor.
#define ONE_WIRE_PIN PIN_C5
 * onewire_reset()
 * Description: Initiates the one wire bus.
// OK if just using a single permanently connected device
void onewire_reset() {
    output_low(ONE_WIRE_PIN);       // pull the bus low for reset
    delay_us(500);
    output_float(ONE_WIRE_PIN);     // float the bus high
    delay_us(500);                  // wait-out remaining initialisation window
 * onewire_write(int8 data)
 * Arguments: a byte of data.
 * Description: writes a byte of data to the device.
void onewire_write(int8 data) {
    int8 count;
    for(count = 0; count < 8; ++count) {
        delay_us(2);                // pull 1-wire low to initiate write time-slot.
        output_bit(ONE_WIRE_PIN, shift_right(&data, 1, 0)); // set output bit on 1-wire
        delay_us(60);               // wait until end of write slot.
        output_float(ONE_WIRE_PIN); // set 1-wire high again,
        delay_us(2);                // for more than 1us minimum.
 * onewire_read()
 * Description: reads and returns a byte of data from the device.
int onewire_read() {
    int count, data;
        delay_us(2);                // pull 1-wire low to initiate read time-slot.
        output_float(ONE_WIRE_PIN); // now let 1-wire float high,
        delay_us(8);                // let device state stabilise,
        shift_right(&data, 1, input(ONE_WIRE_PIN)); // and load result.
        delay_us(120);              // wait until end of read slot.
    return data;
#endif /*ONE_WIRE_C*/
Ds18b20.c
#ifndef DS1820_C
#define DS1820_C
#include "1wire.c"
float ds1820_read();
void ds1820_configure(int8 TH, int8 TL, int8 config);
 * ds1820_read()
 * Description: reads the ds18x20 device on the 1-wire bus and returns
 *              the temperature
float ds1820_read() {
    int8 busy=0, temp1, temp2;
    signed int16 temp3;
    float result;
    //ds1820_configure(0x00, 0x00, 0x00);     //9 bit resolution
    onewire_reset();
    onewire_write(0xCC);            //Skip ROM, address all devices
    onewire_write(0x44);            //Start temperature conversion
    while(busy == 0)                //Wait while busy (bus is low)
        busy = onewire_read();
    onewire_reset();
    onewire_write(0xBE);            //Read scratchpad
    temp1 = onewire_read();
    temp2 = onewire_read();
    temp3 = make16(temp2, temp1);
    //result = (float) temp3 / 2.0;   //Calculation for DS18S20 with 0.5 deg C resolution
    result = (float) temp3 / 16.0;    //Calculation for DS18B20
    delay_ms(200);
    return(result);
And this is my code
if(t>=20)
          output_high(pin_c0);
          printf(lcd_putc,"\fKlima ON\n%f>20'C",t);
          delay_ms(5000);
          goto LOOP1;
But it doesn't make high output pin_c0.
I couldnt understand why?
PostPosted: Tue Apr 28, 2009 11:35 am     Reply with quote
The DS18B20 driver you use is the driver as posted in the CCS Code Library but with the name of the original author and GNU license text removed. I'm not saying that you removed the comments, maybe you copied it from another source, but it would be nice to respect the original author.
Your program is not complete so we can not test it. For example the declaration of 't' is missing. Post a small program demonstrating your problem. Make the program complete, including #fuses, and not larger than 25 lines.
