When using the wizard setup for Pic16F690 I go and assign spi hardware and then look on the i/o tab and it sets the wrong i/o pins for the spi lines. Is this a problem that I should worry about or is it just a fluke in ccs. Also if I use an 18f8722 I go and select both spi1 hardware and spi2 hardware but only spi1 appears on the i/o tab. Is spi2 still being set?
Posted: Fri Mar 06, 2009 2:36 pm
Always post your compiler version, so people who have the same version
of the IDE can try to help.
