keypad 3x4 in 16f877
Felipe Rodolfo
PostPosted: Mon Mar 02, 2009 7:57 am     Reply with quote
how to connect the hardware of a 3x4 keypad matrix with the 16f877 to use kbd.c?
PostPosted: Mon Mar 02, 2009 11:45 am     Reply with quote
You should always look in the CCS Code Library for a driver.
There is one for a 4x3 keypad:
http://www.ccsinfo.com/forum/viewtopic.php?t=26333
There is also a driver in the CCS compiler "drivers" directory, but
the one in the Code Library is more flexible:
c:\program files\picc\drivers\kbd.c
Felipe Rodolfo
Keypad 3x4 in 16f877
PostPosted: Mon Mar 02, 2009 3:03 pm     Reply with quote
Thanks for the reply, but I still have problems with physical connections.
Sydney
PostPosted: Mon Mar 02, 2009 3:05 pm     Reply with quote
Whats the problem?
PostPosted: Mon Mar 02, 2009 3:54 pm     Reply with quote
If you have questions about how to connect the keypad to the PIC,
then post the manufacturer and part number of your keypad.
Also post a link to the data sheet for the keypad.
