Hi-
If I have twoPICs that communicate with eachother can I use 1 oscillator for both (since both want to have the same clock rate)?
Thanks-
Sophi
valemike Guest
Re: Oscillator
Posted: Wed Jul 13, 2005 3:30 pm
Sophi wrote:
Hi-
Thanks-
Sophi
Yeah, you can. You would set your #fuse settings so that you can send CLKOUT from one of the PICs, and feed this to your single oscillator input on the other PIC.
What kind of communication do you want to do? You dont need the same clock rate if it was SPI, I2C, nor UART.
rnielsen
Posted: Thu Jul 14, 2005 8:23 am
Or you could simply have one clock oscillator feed both PIC's OSC1/CLKI and set your #fuses to reflect the proper clock source (EC_IO as an example).
Ronald
Posted: Thu Jul 14, 2005 9:48 am
Hi-
Thanks for replies.
I had thought to save space and parts to use just one oscillator for twoPICs. I ran out of processing space on the 16C67 and wanted to link to a 16C766. Since I can use a 20mHz clk with both.
Sophi
