Simple code for 1way wireless link
E_KARVELAs
PostPosted: Tue Jan 29, 2008 7:27 pm     Reply with quote
HI
i wanted to test some wireless module from SparkFun on a simple one way link but with NO results something wrong on the code.
http://www.sparkfun.com/commerce/product_info.php?products_id=7815
From the code of receiver the #int_rda does not fire .
Can any one help me what i got wrong here???
Trasmitter Code:
#include <18F452.h>
#fuses XT, NOWDT, NOPROTECT,NOLVP,NOBROWNOUT, PUT
#use delay (clock = 4000000)
#use rs232(baud=1200, xmit=PIN_D3, rcv=PIN_D4, ERRORS, STREAM=COM_A)
for(;;){
         if(input(PIN_C4)==0)                  //if button pressed
                output_high(PIN_D2);          //enable Vcc of transmitter module
                output_high(PIN_D1);         //output high Led
                delay_ms(20);
                fputc('T', COM_A);
                delay_ms(20);
                    delay_ms(1000);               //delay some ms
                    output_low(PIN_D1);        // output low led
                    output_low(PIN_D2);        //disable Vcc of transmitter module TSW434
output_high(PIN_D1);                      // if button not pressed then just on off led on pin D1
delay_ms(50);
output_low(PIN_D1);
delay_ms(50);
Receiver Code:
#include <18F452.h>
#fuses XT, NOWDT, NOPROTECT,NOLVP,BROWNOUT, PUT
#use rs232(baud=1200,parity=N, xmit=PIN_D3, rcv=PIN_D2, ERRORS, STREAM=COM_A)
char data;
#int_RDA
   void RDA_isr(void)
   data= fgetc(COM_A);
enable_interrupts(global);
enable_interrupts(int_rda);
for(;;){
        if(data=='T')
                output_low(PIN_D1);
                data=0;
       delay_ms(50);
       output_low(PIN_D1);
       delay_ms(50);
Code can compile OK with no errors i just can't sent data right from Tranmitter-pic to Receiver-pic..
i have wired data-pin from PIC-Receiver wich is rcv=PIN_D2 to the data pin
of RWS 434.
On the ather PIC-Tramitter i have wired the xmit=PIN_D3 to data pin of TWS 434. Confused
---- GREECE ----
E_KARVELAs
PostPosted: Wed Jan 30, 2008 9:02 am     Reply with quote
Hi again!!!
Can Any one offer me a small example code that actually work with these wireless module as a one way link ??
Im trying to be familiar with these wireless module ,sending data from one pic to ather.
---- GREECE ----
E_KARVELAs
PostPosted: Wed Jan 30, 2008 10:09 am     Reply with quote
hi.
I found the problem,Now code works ok!!!!!!!!!!!
The issue was i had to change the ----pin_C7 for Tx
and the ----pic_C6 for Rx
for both pic of course. Cheers!!!Laughing
As i found this info from the datasheets -18F542 -USART.
These code now works file with wireless module from :
transmitter
#include <18F452.h>
#define WireTX PIN_C6 // <--------- C 6
#define WireRX PIN_C7
#use rs232(baud=2400,xmit=WireTX , rcv=WireRX ,ERRORS , STREAM=COM_A )
for(;;){
                delay_ms(20);
                fputc('T',COM_A);
                delay_ms(20);
       delay_ms(50);
       output_low(PIN_D1);
       delay_ms(50);
Receiver
#include <18F452.h>
#define WireRX PIN_C7 //<-----
#use rs232(baud=2400, xmit=WireTX, rcv=WireRX, ERRORS, STREAM=COM_A)
unsigned int8 data;
int1 flag=0;
#int_rda
   void rd_isr(void)
   disable_interrupts(INT_RDA);           // Disable Serial Recieve Interrupt
   disable_interrupts(GLOBAL);            // Disable Global Interrupts
   data= fgetc(COM_A);
 if(data=='T'){
              flag=1;
   enable_interrupts(INT_RDA);
for(;;){
        if(flag==1)
                output_low(PIN_D1);
            flag=0;
       delay_ms(50);
       output_low(PIN_D1);
       delay_ms(50);
---- GREECE ----
anandpv2009
Thanks Thanks
PostPosted: Mon Sep 21, 2009 12:26 pm     Reply with quote
Thank u friend for this code.....................
It works...............
