Posted: Sat Oct 19, 2013 2:01 pm |
Quote: | The sensor is powered with +3.3vcc and the PIC is +5vcc both of them has common Gnd.
Change your #use i2c() statement to this:
Quote: |
#use i2c(Master, sda=PIN_C4, scl=PIN_C3, FORCE_HW, SMBUS) |
Quote: | The ADD0 pin of the TMP102 in connected to ground.
#define TMP_RD 0x93
#define TMP_WR 0x92 //Assume ADR0 is tied to VCC
These statements conflict with each other. The slave address is set by
the A0 connection. What is the true connection on your board ? If it's
really connected to GND, then the TMP102 slave address is 0x90 for
writing and 0x91 for reading. |
kufre
TMP102 temperature Sensor not working with PIC16F877A |
Posted: Sat Oct 19, 2013 4:38 pm |
Am sorry for the mix up. Actually, I connected the ADD0 to +vcc ( from sparkfun sample code).
Thanks for your reply.
I connected the ADD0 to GND and modify the code slightly to check if there is acknowledgement.
#include <16F877A.h>
#FUSES NOWDT
#FUSES HS
#FUSES NOBROWNOUT
#FUSES NOLVP, PUT
#use delay(clock=20000000)
#use i2c(Master, sda=PIN_C4,scl=PIN_C3, FORCE_HW, SMBUS ) // Configure Device as Master
#use rs232(baud=4800,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=UART, ERRORS)
#define TMP_RD 0x91
#define TMP_WR 0x90 //Assume ADR0 is tied to GND
#define TEMP_REG 0x00
delay_ms(3000);
fprintf(UART,"TMP102 Example \r\n");
fprintf(UART,"Reading Started...\r\n");
while (1)
unsigned int8 msb, lsb;
int8 temp;
int re, re2, re3;
i2c_start();
delay_ms(50);
re=i2c_write(TMP_WR); //We want to write a value to the TMP
delay_ms(50);
re2=i2c_write(TEMP_REG); //Set pointer register to temperature register (it's already there by default, but you never know)
i2c_start();
delay_ms(50);
re3=i2c_write(TMP_RD); // Read from this I2C address, R/*W Set
delay_ms(50);
msb= i2c_read(); //Read the MSB data
lsb = i2c_read(); //Read the LSB data
i2c_Stop();
printf(" %u ", msb); //
printf(" %u ", lsb); //
printf(" re:%d re2:%d re3:%d\n", re, re2, re3);
delay_ms(3000);
I obsvered that the acknowledgement bits stored in re, re2, re3 are all "1" instead of "0" which means there's no acknowledgement at all.
The MSB and LSB still return 0xFF (255).
Pls could it be that the tmp102 is bad or there's something am missing out?
Your Suggestions is much appreciated. |
Posted: Sat Oct 19, 2013 5:19 pm |
Run this program. See if it detects the TMP102:
http://www.ccsinfo.com/forum/viewtopic.php?t=49713
You will have to change the top lines of the program to fit your PIC,
#fuses, #use delay, etc. Make sure you change the #use i2c to use
your pins, and add FORCE_HW and SMBUS.
Quote: |
delay_ms(3000);
while (1)
int8 temp;
int re, re2, re3; |
Do not declare local variables in mid-code. Always put them at the start of
the function. In this case, move them up to the start of main().
i2c_Stop(); |
Here, you have changed this from your original code. I have no idea why.
It was correct in your first code. The last call to i2c_read() must give it
a 0x00 parameter. You removed it. Put it back in.
I don't see any reason for Nobrownout. It's highly helpful. Only in a very
low power situation (battery operated device) should you consider having
no brownout. Change it to BROWNOUT. |
kufre
Posted: Sun Oct 20, 2013 12:37 pm |
Thanks for the Link.
I modified and ran the code at http://www.ccsinfo.com/forum/viewtopic.php?t=49713, its detect the TMP102 and return the result as:
Quote: |
Start:
ACK addr: 90
Number of i2c chips found: 1
I then copied part of it to my main code and is working (reading the temperature).
I really appreciate your support and explanations.
Once again thanks. |
