MPLAB6 linker problem
terry
PostPosted: Mon Sep 27, 2004 4:02 am     Reply with quote
How do I stop MPLAB from trying to run a linker with PCM. I get the following error messge:
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "F:\PICC\V3190\PICC\Ccsc.exe" sensortx1.c
No Errors
Skipping link step. Not all sources built successfully.
BUILD FAILED: Mon Sep 27 10:54:18 2004
The .hex file is generated OK so I could ignore the BUILD FAILED message.
Regards
Re: MPLAB6 linker problem
PostPosted: Mon Sep 27, 2004 7:09 am     Reply with quote
Clean: Done.
No Errors
Regards
In the 'language tool' setup, there should be two different references for the CCS compiler. One is called something like 'CCS C Compiler', while the other refers to the chip versions (PIC12/4/16/18). This fault is caused by having the wrong one selected. Why there are the two references, I don't know!. If you haven't got the second reference, run "ccsc +setup", to create it.
PostPosted: Fri Oct 29, 2004 3:57 pm     Reply with quote
I am havng the exact same problem. I get a "Skipping link step. Not all sources built successfully" after a successful compile. Unfortunately there is only one entry in the Language Toolsuite for CCS C Compiler and nothing like PIC12/4/16/18. Any suggestions?
Thanks a lot,
Mark
PostPosted: Fri Oct 29, 2004 4:01 pm     Reply with quote
Check the instructions for installing CCS with MPLAB 6.xx in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=18362
PostPosted: Fri Oct 29, 2004 5:06 pm     Reply with quote
Sorry about my previous post. I missed the last line about the ccs +setup. Problem is solved. Thanks for the help.
mark
