deuce Guest
max485 connection to PIC16f877 |
Posted: Thu Jan 19, 2006 9:33 pm |
i am confuse what pins of max485 needed to be conected to my PIC16f877...so that i can comunicate with my other PIC16f877..
For both PIC...there a LCD and a keypad each...it will be great if u can give me a source code so i can comunicate with my two PIC..thanks
HEres a data sheet of max485..
http://pdfserv.maxim-ic.com/en/ds/1111.pdf |
Been There Guest
'485 Comm |
Posted: Mon Jan 23, 2006 1:01 am |
The first question is whether you can afford 4 wires between your '485 devices. If so, then the '485 parts are more like drivers.
The next question is if you are doing a master / slave arrangement then the 2 wires is ok. If either side has to talk, then you need to stick with the 4 wire arrangement.
If you are limited to 2 wires for communication between your PICs, then you have to switch between transmit and receive (-RE & DE).
As to the ports, use the TX and RX ports just as you would if you were interfacing with a RS232 port. There are tons of free code examples on the web. Try looking at the MicroChip site. |
crushneck
Posted: Wed Jan 25, 2006 1:55 am |
Quote: | If you are limited to 2 wires for communication between your PICs, then you have to switch between transmit and receive (-RE & DE). |
i dun understand this part...can u explain?
yes im using master/slavce arangement...heres my connection from max485 to PIC18f452...since theres not enough ram to compile for PIC16f877...
RO-RC7
-RE-RC4
DE-RC5
DI-RC6
pin5-GND
pin8-VCC
THe rest of the pins goto other max485, A-A, B-B...
heres my soure code for master
Code: | //master
#include<18f452.h>
#fuses HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, PUT
#use delay(clock = 20000000)
#define RS485_ID 0x10 // The device's RS485 master address
#define RS485_USE_EXT_INT TRUE // Select asynchronous serial interrupt
#include<RS485.c>
#include <lCD420.c>
int buffer[40];
int next_in = 0;
int next_out = 0;
#INT_RDA
void serial_isr()
int t;
buffer[next_in] = fgetc(RS485);
t = next_in;
next_in = (next_in+1) % sizeof(buffer);
if(next_in == next_out)
next_in=t; // Buffer full !!
int j;
int data_received[32];
//enable_interrupts(INT_RDA);
// enable_interrupts(GLOBAL);
rs485_init();
rs485_wait_for_bus(FALSE);
//send address=0x11, length = 1, msg=3
if(rs485_send_message(0x11, 1, 3))
/*output_low(PIN_B1);
output_high(PIN_B1);
output_low(PIN_B1);*/
lcd_gotoxy(1,3);
printf(lcd_putc, "\n\rADC (V):test\r\n");
delay_ms(5);
if(rs485_get_message(data_received, FALSE))
for(j=0; j<3; ++j)
data_received[j] = buffer[j];
if(data_received[2]==6) //if slave receives the number 3 successfully
{ //slave will send back number 6
lcd_gotoxy(1,4);
/*output_low(PIN_B2);
output_high(PIN_B2);
output_low(PIN_B2);*/
and heres the slave..
Code: | //slave
#include<18f452.h>
#define RS485_ID 0x11 // The device's RS485 slave address or ID
#include<RS485.c>
#include <lCD420.c>
int buffer[40];
int next_in = 0;
int next_out = 0;
#INT_RDA
void serial_isr()
int t;
t = next_in;
int j;
// enable_interrupts(INT_RDA);
//enable_interrupts(GLOBAL);
rs485_init();
if(rs485_get_message(data_received, TRUE))
for(j=0; j<3; ++j)
if(data_received[0] == 0x11)
lcd_gotoxy(1,4);
output_low(PIN_B2);
output_low(PIN_B2);
//after receive successfully, respond to master by sending number 6
if(rs485_send_message(0x10, 1, 6))
lcd_gotoxy(1,3);
/* output_low(PIN_B1);
output_low(PIN_B1);
Muhammad Ashraf Khatri
Posted: Thu Jan 26, 2006 1:21 am |
what can we do if 1 is master and more then 1 are in slave configuration
how can we then program |
funmix
Posted: Fri Apr 06, 2007 5:56 am |
how you verify your code is working? By watching the LED blinking ? |
funmix
Posted: Sun Apr 08, 2007 5:43 am |
I tested the code. I found that the led of the master keep blinking. It means that master keep receive message only. Slave is doing nothing. I also tested with Hyperterminal, there is nothing display on the window.
Can someone please help? |
Ttelmah Guest
Posted: Sun Apr 08, 2007 8:41 am |
There is a potential problem, if you disable the RS485 receiver (you are connecting to this pin, but I have not lookd at what you do with this). Basically, if you disable the receiver, the output pin, goes high impedance. On the TTL serial input of the PIC, the incoming line needs to be _high_ when data is not available. If it drops, this is seen as receive data. If you are going to disable the receiver when sending, you need to add a pull up resistor, or garbage data will be received. In general most people using RS485, do not disable the receiver. Instead, they accept that the transmitting chip wll receive everything it sends, and leave the receiver enabled. Also, with the MAX485, you should be looking at arranging your 485 bus termination, so that a bias is applied to the bus, ensuring that the data output is high, when nothing is being sent, or, there will be garbage data received when the bus is idle. There are some other RS485 receiver chips, that do not require this, and also electronic terminators available, that apply the correct bias to the bus.
funmix
Posted: Mon Apr 09, 2007 6:18 pm |
Both PICs hardware.
Rx -- RO
Tx -- DI
RC5 -- DE
/RE -- GND
A--A
B--B
Pullup - 0.5K for both A and B buses
This is how i connect in my hardware. |
Humberto
Ttelmah Guest
Posted: Tue Apr 10, 2007 2:27 am |
There is only one 'bus'. A, and B, are a differential _pair_ of signals, comprising just a single data path. There should be termination _between_ these signals at the ends of the bus, matching the characteristic impedance of the wiring used. Normally 100R. This becomes essential at high data rates, but for simple testing at low rates, the system may operate OK without it.
Now a _slight_ pullup on one line, and a pull down, on the other, will ensure that the bus 'idles' to the 'off' state. You want the 'A' line pulled down, and the 'B' line pulled up, and the resistors should be chosen to give 200mV at least between the lines. You can get active terminators that do this. The simplest setup that gives this, is a 1200R resistor from the 0V connection to the 'A' line, 120R from A to B, and 1200 from B to +5v. This gives a characteristic impedance of 100R, and 238mV between the lines.
Pull the application report number SLLA070C from the Texas instrument site, for an overview of other termination methods, and how the bus sould be configured.
cheehow
Posted: Mon Nov 08, 2010 10:24 am |
HI crushneck,
i m also doing the same things as what u have done it ... so, can u show me ur sucessed codes to me and the circuit diagram as well .. your help would be appreciated !! thxssss
Regards
Chee how |
Humberto
Posted: Mon Nov 08, 2010 10:56 am |
Hi Chee how,
The last time that crushneck posted in this forum was on: Feb 10, 2006 hence you have minimal chance to contact
him through this panel, try to send him a pm or describe your problem in this thread and you will get further help
from another members.
Regards. |
