arrow
Writting to EEPROM form PICC? |
Posted: Tue Dec 27, 2005 7:22 am |
Hi
Is there any way to write to internal EEPROM from the C code?
Regards
a. |
John Morley
Posted: Tue Dec 27, 2005 8:10 am |
Sure there is, look in the manual for the function Write_EEProm().
John _________________ John Morley |
MikeValencia
Posted: Tue Dec 27, 2005 8:11 am |
Of course.
write_eeprom(address, 8bit_value);
also look at the FAQ to write >8-bit values:
http://www.ccsinfo.com/faq/?24 |
MikeValencia
Posted: Tue Dec 27, 2005 8:13 am |
or did you mean to ask:
How do I pre-populate the eeprom with certain values while programming the PIC. That's possible too, but i'd have to do a search in the forum for that. I know the topic's been answered a few times before. |
arrow
Posted: Tue Dec 27, 2005 8:20 am |
Hi
Thank you. Yes you are right about pre- populating the EEPROM.
From a previous thread I understand that have to use: #ROM command.
Regards
a. |
ckielstra
Posted: Tue Dec 27, 2005 8:27 am |
A few examples:
Code: | // Example to set words:
#ROM 0xF00000 = {1, 2, 3, 4, 5}
// Example to set bytes:
#ROM int8 0xF00000 = {1, 2, 3, 4, 5}
// Example to set a string of bytes:
#ROM 0xF00010 = {"12345"} |
