PIC18F452 & Proteus
Angelo
PIC18F452 & Proteus
PostPosted: Fri Oct 06, 2006 8:35 am     Reply with quote
rberek
PostPosted: Sat Oct 07, 2006 7:51 pm     Reply with quote
Proteus will simulate that circuit correctly if you tie MCLR high and use the following program.
#include <18F452.h>
#use delay(clock=10000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,bits=8,ERRORS)
 printf("CONTROL LED WITH PIC\n\r");
do {
printf("\n\r");
printf("Press any key to turn on led...\n\r");
getch();
output_high(pin_d0);
printf("Press any key to turn off led...\n\r");
getch();
output_low(pin_d0);
} while (TRUE);
Angelo
PostPosted: Tue Oct 10, 2006 9:51 am     Reply with quote
Thank you rberek. It is work!!!
40inD
PostPosted: Thu Dec 11, 2008 10:56 am     Reply with quote
When I try to simulate this code:
http://www.ccsinfo.com/forum/viewtopic.php?p=74157#74157
http://www.ccsinfo.com/forum/viewtopic.php?t=19255
in Proteus for PIC18F452 or 18F4620 I get nothing or get zeroes in address strings.
When I simulate this code compiled for 16F877 it works fine.
I can't understand why this code does not work for 18 series?
Oscilloscope shows continuous impulse train about 5 us in period.
