Langton
Crashing ONLY on debug |
Posted: Thu Nov 08, 2012 11:04 pm |
Hi Guys (and Gals),
PCH 4.137
Windows 7
MPLABX
18F45K22
Everything was sweet (except a EEPROM write bug which I suspected may have been to do with the compiler 4.132) so I did an update to 4.137 and now it can clean and build but as soon as I go to debug it crashes. I can program after a build so my Real Ice has no dramas. The ONLY thing that has changed is the 4.137. I re-did the project from scratch in case there was a make file drama or something like that, but no joy there either. Searched Google, came up with a couple of things but no success. Any suggestions please?
here is what MPLABX says...
Code: | make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory `Z:/Analogue firmware/SWCauto2/SWCauto2.X'
make -f nbproject/Makefile-default.mk dist/default/debug/SWCauto2.X.debug.cof
make[2]: Entering directory `Z:/Analogue firmware/SWCauto2/SWCauto2.X'
gnumkdir -p build/default/debug
gnumkdir -p dist/default/debug
"C:\PROGRA~1\PICCH\CCSC.exe" out="dist/default/debug" "SWCauto2.c" +FH +DF #__DEBUG=1 +ICD +Y=9 +EA +DF +LN +T +A +M +J +ES +Z +PE #__18F45K22=TRUE
make[2]: *** [build/default/debug/SWCauto2.o] Error -1073741819
make[1]: *** [.build-conf] Error 2
make[2]: Leaving directory `Z:/Analogue firmware/SWCauto2/SWCauto2.X'
make[1]: Leaving directory `Z:/Analogue firmware/SWCauto2/SWCauto2.X'
make: *** [.build-impl] Error 2
BUILD FAILED (exit value 2, total time: 6s) |
Posted: Mon Nov 12, 2012 3:24 am |
How much ROM is your code using (when you build it without DEBUG)?. Is it using more with the new compiler than the old?.
Have you got the debug patch for PIC18F46K22 loaded?. This applies to your chip as well (it ought to be called PIC18xxK22), and causes a problem programming an area of memory just below the debug executive.
gpsmikey
Posted: Mon Nov 12, 2012 9:54 am |
Does that debug patch apply to Mplabx? From reading the post at Microchip, it seemed to indicate that it only affected MPLAB 8.63 and was going to be fixed in the February release. http://www.microchip.com/forums/m552373.aspx (I'm busy working on my little project with the 18f25k22, so this is very interesting - normally I trip over these things).
mikey _________________ mikey
Posted: Mon Nov 12, 2012 10:05 am |
It is one of those 'some people get it' problems.
It is _only_ an issue if your code is putting data at the top of memory, right adjacent to the debug executive. Hence my question about 'size'. Have had loads of people working on code using these chips, without ever hitting this issue, but a few people have hit it, and then the fix seems to work.
My 'thought', was that the new compiler, might be making the code a fraction larger (possibly the EEPROM fix taking more space...), and hence hitting this problem. The problem vanishes when debug is not running, which would also 'fit' with the behaviour.
The fix, simply reprograms the address that MPLAB thinks is the size of the chip. It is meant not to apply to latter releases of MPLAB (they claimed it was fixed six months or more ago), but I've still seem people getting intermittent problems here.
Langton
Posted: Mon Nov 12, 2012 1:46 pm |
I agree that is seem exactly like a similar patch is required. I checked and it is 8.63 only, that problem must have made a few people lose some hair. Yesterday I sent all the data to support and I've just (30min ago) went back to 4.132 which is now working perfectly, better the devil I know for now. Thanks guys for your replies, hopefully this will help someone else down the track |
