***Error 17 "C:\pic\16F688.h Line (9,10); Too many nested #INCLUDEs
then it show .h file
#include <16F688.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#use delay(clock=20000000)
help please
dyeatman
Posted: Thu Oct 07, 2010 6:49 am
Your first line <includes> the file 16F688.h then the 16F688.h file you
created <includes> the same name again. In addition the included file
repeats the fuses and #use delay lines.
Your fuses and #use delay are already in the main program so the best
course is to simply rename the file you created called 16F688.h and let the
program use the CCS provided 16F688.h device header file that should be in
your PICC/devices directory.
Add the #device adc=8 line just after the FUSES line in your main program.
Finally, delete the set_tris_c(0x00) line and let the compiler handle it. Since
you are not using fast_io (and you don't need it) the line has no real effect. _________________ Google and Forum Search are some of your best tools!!!!
