thomas Guest
Maximum array size? |
Posted: Sun Jun 15, 2003 2:49 pm |
I am using PIC16F876 with CCS version 3.0. When I write "int array[256];" It flags an error, saying that the maximum subscription is exceeded. What is the maxium size for an array? How do allocate 256 byte? This PIC has more than 256 bytes of RAM. Is it not?
Thanks!
Thomas
Original Post ID: 144515263 |
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Re: Maximum array size? |
Posted: Sun Jun 15, 2003 5:44 pm |
Thomas,
I'm quoting this from the CCS help:
"A subscript to a RAM array must be at least 1 and not more than 128 elements. Note that large arrays might not fit in a bank. ROM arrays may not occupy more than 256 locations. Arrays are limited to 5 dimensions."
Note that although PIC16F87 has 368 bytes of memory, it's divided in 4 banks. Compiler can't allocate an array over more than one bank, so your array sizes are limited to the bank size.
Ali
Original Post ID: 144515267 |
Mike Broom Guest
Posted: Mon Jun 16, 2003 6:05 am |
:=Hello,
:=I am using PIC16F876 with CCS version 3.0. When I write "int array[256];" It flags an error, saying that the maximum subscription is exceeded. What is the maxium size for an array? How do allocate 256 byte? This PIC has more than 256 bytes of RAM. Is it not?
:=Thanks!
:=Thomas
Thomas the following code snippit will do what you want, and can actually address all available ram with a little tweaking of the #reserve's and an additional a bit of code to address bank 0 RAM
regards
Mike Broom
Code: | #include <16f876.h>
#reserve 0xa0xef
#reserve 0x110x16f
#reserve 0x190x1df
void WriteArray(int16 Index, int8 Value)
int8 Bank;
int8 Offset;
Bank = 1; //Start in bank 1 no offset
Offset = Index;
if(Index >= 0x50)
Bank = 2; //Jump to bank 2 when we have filled bank 1
Offset = (Index - 0x50); //subtract size of bank 1
if(Index >= 0xB0)
Bank = 3; //Jump to bank 3 and subtract
Offset = (Index - 0xB0); //Size bank 1 & 2
switch(Bank)
case 1:
write_bank(1,Offset,Value);
case 2:
write_bank(2,Offset,Value);
case 3:
write_bank(3,Offset,Value);
default:
int8 ReadArray(int16 Index)
int8 Bank;
int8 Offset;
if(Index >= 0x50)
if(Index >= 0xB0)
Offset = (Index - 0x60); //Size bank 1 & 2
switch(Bank)
case 1:
return(read_bank(1,Offset));
case 2:
case 3:
default:
WriteArray(MyArray_Element,Value); //This will write to any cell upto 256
MyArray_Element_Value = ReadArray(MyArray_Element); //This will read fro the array
Original Post ID: 144515289 |
thomas Guest
Posted: Mon Jun 16, 2003 1:25 pm |
Perfect! This is jus what I need. Thank you very much!
thomas
:=:=Hello,
:=:=I am using PIC16F876 with CCS version 3.0. When I write "int array[256];" It flags an error, saying that the maximum subscription is exceeded. What is the maxium size for an array? How do allocate 256 byte? This PIC has more than 256 bytes of RAM. Is it not?
:=:=Thanks!
:=:=Thomas
:=Thomas the following code snippit will do what you want, and can actually address all available ram with a little twaking of the #reserve's and an additional a bit of code to address bank 0 RAM
:=regards
:=Mike Broom
:=#include <16f876.h>
:=#reserve 0xa0:0xef
:=#reserve 0x110:0x16f
:=#reserve 0x190:0x1df
:=void WriteArray(int16 Index, int8 Value)
:= int8 Bank;
:= int8 Offset;
:= Bank = 1; //Start in bank 1 no offset
:= Offset = Index;
:= if(Index >= 0x50)
:= Bank = 2; //Jump to bank 2 when we have filled bank 1
:= Offset = (Index - 0x50); //subtract size of bank 1
:= if(Index >= 0xB0)
:= Bank = 3; //Jump to bank 3 and subtract
:= Offset = (Index - 0xB0); //Size bank 1 & 2
:= switch(Bank)
:= case 1:
:= write_bank(1,Offset,Value);
:= break;
:= case 2:
:= write_bank(2,Offset,Value);
:= break;
:= case 3:
:= write_bank(3,Offset,Value);
:= break;
:= default:
:= break;
:=int8 ReadArray(int16 Index)
:= int8 Bank;
:= int8 Offset;
:= Offset = (Index - 0x60); //Size bank 1 & 2
:= switch(Bank)
:= case 1:
:= return(read_bank(1,Offset));
:= break;
:= case 2:
:= break;
:= case 3:
:= break;
:= default:
:= break;
:=void main(void)
:= WriteArray(MyArray_Element,Value); //This will write to any cell upto 256
:= MyArray_Element_Value = ReadArray(MyArray_Element); //This will read fro the array
Original Post ID: 144515303 |
