just a guest Guest
Problem with disabled Interrupts |
Posted: Mon Dec 19, 2005 8:53 am |
Hi NG,
I have a application (with the PIC18F458) there is very important, that the Interrupts not disabled.
The Compilers say Warnings like:
Interrupts disabled during call to prevent re-entrancy: (@DIV1616)
Can I say the compiler to use copy's of this internal routines?
An other problem I have with read_eeprom() and write_eeprom().
Why does the compiler disable Interrupts during read_eeprom()? The Microchip Data Sheet say's it is necessary to disable Interrupts during writing to EEPROM, not at the read-sequence.
Best Regards
Just a Guest |
MikeValencia
Posted: Mon Dec 19, 2005 1:08 pm |
If you call a delay_ms or delay_us function within an isr, then you'll get that re-entrancy warning. Try to refrain from even delaying in an isr. otherwise, you should write your own my_delay_ms() routine that you will use in your isr, to avoid reentrancy conflicts. |
just a guest Guest
Posted: Tue Dec 20, 2005 4:53 am |
thank you for your replay, but this is not the problem. Let me explain.
Here is a sample code:
#include "18F458.h"
int16 x, y, z;
#int_timer0
void T0Int(){
z = x/y;
int16 i, j, k;
void main(){
k = i/j;
I compile it with:
ccsc +FH +EA test.c
The result (test.err):
>>> Warning 216 "C:\PROGRA~1\PICC_2~1\t.c" Line 19(0,1): Interrupts disabled during call to prevent re-entrancy: (@DIV1616)
Memory usage: ROM=1% RAM=2% - 3%
0 Errors, 1 Warnings.
In some application it is a problem to disable Interrupts. To solve this problem, at the Interrupt the compiler have to use a copy from the internal @DIV1616-Routine.
My question:
Is it possible to say the compiler to use a copy of those internal routines?
If not: Perhaps this is a suggestion for CCS. This point is one of the few disadvantage of the CCS-Compiler.
Best Regards
Just a guest[/code] |
Ttelmah Guest
Posted: Tue Dec 20, 2005 10:43 am |
You should consider the sort of durations that using arithmetic in the interrupts involves. You are talking in the order of typically 300 instructions to perform this sum, and with the perhaps 50 instruction overhead for this interrupt handler, this is quite a significant total time. Now, with that 'caveat', if you must have such a sum, then just generate a simple division routine. Something like:
int16 div16(int16 a,int16 b) {
int16 mask=1;
int16 res=0;
if (a==0) return(0);
while (a>b) {
b=b<<1;
mask=mask<<1;
if (a==b) return(mask);
b=b>>1;
mask=mask>>1;
while (a) {
if (a>=b) {
a=a-b;
res=res+mask;
mask=mask>>1;
b=b>>1;
if (mask==0) return(res);
return(res);
This gives variable duration, according to the size of the values, but is not too inefficient. Code it as inline, to remove the overhead of a call/return. If you write it directly into the handler, and allow it to use the original numbers (remember it will change these), you save about 10 instructions of setup time.
You can also reduce the times involved a lot, if the divisor, is an 8 bit value. The above is very efficient, if you want the remainder, since this is left in 'a'.
Posted: Tue Dec 20, 2005 12:18 pm |
Quote: | My question:
Is it possible to say the compiler to use a copy of those internal routines? |
The following program shows how to use the "#org default" directive
to create a copy of the CCS math library code. Compile this program
and then go to the View / Disassembly Listing menu in MPLAB.
You will see there are two copies of the DIV1616 routine.
#include <18F452.h>
#fuses XT,NOWDT,NOPROTECT,PUT,BROWNOUT,NOLVP
#org 0x1000, 0x10FF DEFAULT
#int_timer0
void my_function(void)
int16 x, y, z;
z = x/y;
#org DEFAULT
int16 a, b, c;
c = a/b;
Just a Guest Guest
Posted: Fri Dec 23, 2005 4:41 am |
it works fine, thank you very much.
Also many thanks @Ttelmah!
Just a Guest |
