Custom LCD Characters
wmeade
PostPosted: Fri Sep 12, 2003 8:38 am     Reply with quote
I would like to create a custom LCD character to display on my 4x20 LCD. This was rather easy in PBP, but appears to be more complicated in PICC. I searched the forum and found one message that pertained to my question but it was using functions that are not in the LCD.C, which is what I am using. Should I be using a different driver or will the LCD.C work for loading a custom character into the CG_RAM on the Display? Thanks in advance........
Mark
PostPosted: Fri Sep 12, 2003 9:33 am     Reply with quote
Read the datasheet for the LCD controller that you are using. It is pretty simple to implement you just have to know what to do.
Here is one I wrote a while back. I think you should be able to the the 'lcd_send_byte' from LCD.C with this.
#define LCD_COMMAND             0
#define LCD_DISPLAY             1
#define LCD_CG_RAM              0x40
* NAME:        Store_Custom_Char
* DESCRIPTION: Stores the custom characters in the CGRAM of the LCD Display
* PARAMETERS:  none
* GLOBALS:     none
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
void Store_Custom_Char(void)
  LCD_Write(LCD_COMMAND, LCD_CG_RAM);
  /******************************* 'É' **************************************/
  LCD_Write(LCD_DISPLAY,0x02);   /*       X  */
  LCD_Write(LCD_DISPLAY,0x04);   /*      X   */
  LCD_Write(LCD_DISPLAY,0x1F);   /*    XXXXX */
  LCD_Write(LCD_DISPLAY,0x10);   /*    X     */
  LCD_Write(LCD_DISPLAY,0x1E);   /*    XXXX  */
  LCD_Write(LCD_DISPLAY,0x00);   /*          */
  /******************************* 'Ç' **************************************/
  LCD_Write(LCD_DISPLAY,0x0E);   /*     XXX  */
  LCD_Write(LCD_DISPLAY,0x11);   /*    X   X */
  LCD_Write(LCD_DISPLAY,0x0C);   /*     XX   */
  /******************************* 'À' **************************************/
  LCD_Write(LCD_DISPLAY,0x0A);   /*     X X  */
  /******************************* 'Ô' **************************************/
  /******************************* 'é' **************************************/
  /*************************** Down arrow ***********************************/
  LCD_Write(LCD_DISPLAY,0x15);   /*    X X X */
  /*************************** Up arrow *************************************/
  /*************************** Not Used *************************************/
wmeade
PostPosted: Fri Sep 12, 2003 12:44 pm     Reply with quote
Thanks for the quick response mark. I was able to load and display my custome cursor.
Below is how I loaded it and then displayed it for anyone that may be doing the same thing using LCD.C.
// Load Custome Cursor Into LCD CG RAM
lcd_send_byte(0,0x40); // (0 = command mode) write to LCD CG Ram location 0
lcd_send_byte(1,0x08); // (1 = display mode) load cursor line 1 of 8
lcd_send_byte(1,0x0C); // (1 = display mode) load cursor line 2 of 8
lcd_send_byte(1,0x0E); // (1 = display mode) load cursor line 3 of 8
lcd_send_byte(1,0x0F); // (1 = display mode) load cursor line 4 of 8
lcd_send_byte(1,0x0E); // (1 = display mode) load cursor line 5 of 8
lcd_send_byte(1,0x0C); // (1 = display mode) load cursor line 6 of 8
lcd_send_byte(1,0x08); // (1 = display mode) load cursor line 7 of 8
lcd_send_byte(1,0x00); // (1 = display mode) load cursor line 8 of 8
// Display Custome Cursor on LCD from LCD CG RAM Location 0
lcd_send_byte(1,0); // (1 = display mode) (0 = CG RAM location)
Bryan
View user's profile Send private message Send e-mail AIM Address
PostPosted: Fri May 20, 2005 11:11 am     Reply with quote
Where did you put this code in your main program to get it to load and display your custom cursor? I tried doing this right after lcd_init() in main but it doesn't display anything - Does this need to be inside the lcd_init() function?
Mark
PostPosted: Fri May 20, 2005 11:55 am     Reply with quote
These only store the data in the LCD. Take a look at the datasheet. You access the custom characters with a code (0-7 in this case).
  printf(lcd_putc,"This is custom char 2 \1");
  printf(lcd_putc,"This is the fourth custom char \4");
The first custom address is stored at 0 so that one is a bit tricky since \0 also signals the end of a string.
Bryan
PostPosted: Fri May 20, 2005 12:15 pm     Reply with quote
Thanks for the help Mark! When I tried this out, I needed to clear the display after calling the Store_Custom_Char() function before I was able to get anything to output. Do you know why this is? Also, you were right \0 doesn't work correctly so I may just store the 2 custom characters that I need for my project in positions 1 and 2 since they work fine.
Mark
PostPosted: Fri May 20, 2005 2:50 pm     Reply with quote
You can make the 0 char work but probably not in a printf().
CharlieGill
PostPosted: Sun May 22, 2005 7:16 pm     Reply with quote
If you encode your custom characters using binary constants it makes it easier to visualize what the character looks like.
0b0000100
0b0001110
0b0010101
0b0000100
0b0000100
0b0000100
0b0000000
Charlie
Mark
PostPosted: Sun May 22, 2005 9:00 pm     Reply with quote
I added the code formating to my orginal post. I think they stand out pretty well Very Happy
