I have a question about connecting an LCD. The LCD is connected to a PIC16F873A. DB0..DB5 are connected to Port_A 0..5. DB6..DB7 is connected to Port_C 0..1. How do I define these Ports to write to the LCD with only one 8Bit-value?
Can I use the lcd.c file in my hardware setup? I tried to add it in my project file, but if I build the project, I get the errormessage "InvalidOption: +EXPORT". But this option is not set in the build options. What could be the problem?
