Write a Float variable in the internal EEPROM memory
morris888
PostPosted: Fri Oct 23, 2009 2:54 pm     Reply with quote
Hello, I'm trying to save a float variable, that I'm using in a program in the internal EEPROM memory. I found this example in CCS FAQ, but I still don't know how to save my float variable.
WRITE_FLOAT_EXT_EEPROM(long int n, float data) {
   int i;
   for (i = 0; i < 4; i++)
      write_ext_eeprom(i + n, *((int8*)&data + i) ) ;
float READ_FLOAT_EXT_EEPROM(long int n) {
   int i;
   float data;
      *((int8*)&data + i) = read_ext_eeprom(i + n);
   return(data);
PostPosted: Fri Oct 23, 2009 3:48 pm     Reply with quote
Use the routines from this CCS driver file. It has routines for internal eeprom:
c:\program files\picc\drivers\internal_eeprom.c
The routines have instructions:
// Purpose: Write a floating point number to internal eeprom
// Inputs: 1) An eeprom address. Four eeprom locations will be used.
// 2) The floating point number to write to internal eeprom
// Outputs: None
void write_float_eeprom(INT_EEPROM_ADDRESS address, float data)
// Purpose: Read a floating point number from internal eeprom
// Inputs: An eeprom address
// Outputs: The floating point number read from the internal eeprom
float read_float_eeprom(INT_EEPROM_ADDRESS address)
mutthunaveen
i had the same question
PostPosted: Sat Oct 24, 2009 7:07 am     Reply with quote
thanks PCM programmer
