33FJ64GP802 Audio DAC clock problem
mkent
PostPosted: Thu Jun 09, 2011 5:06 pm     Reply with quote
I am using the Audio DAC on the '802 to create a minimum shift keying modulation of 2400 Hz and 3600 Hz.
The auxiliary oscillator setup is found in the Oscillator part 3 of the dsPIC33F Family Ref. Manual.
crystal = 7.3728 Mhz, N1 /2 = 3.6864 Mhz, M x48 = 176.9472 Mhz (Fvco)
Fvco is selected as the Aux Osc
176.9472 / 8 = 22.1184 Mhz ACLK
DAC clock = 22.1184 / 256 = 86.4 Khz
I measure 43.2 Khz as my DAC clock and have checked the setup many times.
The code isn't very long so I'll post it all.
//INCLUDES -------------------------------------------------------------------------------------//
   #include <CaveRoverControl.h>
   #include <math.h>
   #include <stdio.h>
//DEFINES --------------------------------------------------------------------------------------//
//--INPUTS -------------------------------------------------------------------------------------//
//--OUTPUTS ------------------------------------------------------------------------------------//
//   #define DAC1LN_MSK    PIN_A3                    //DAC left channel negitive output
//   #define DAC1LP_MSK    PIN_A4                    //DAC left channel positive output
//--REGISTERS ----------------------------------------------------------------------------------//
//   Oscillator
   #word OSCCON = 0x0742                     //Oscillator control register
   #word CLKDIV = 0x0744                     //Oscillator clock control
   #word PLLFBD = 0x0746                     //PLL feedback
   #word ACLKCON = 0x074A                          //Aux clock control register address
//   DAC
   #word DAC1CON = 0x03F0                          //DAC control register
   #word DAC1STAT = 0x03F2                         //DAC status and control register
   #word DAC1DFLT = 0x03F4                     //DAC default register
   #bit  LEMPTY  = 0x03F2.8                      //Left channel input buffer empty bit
//--CONSTANTS ----------------------------------------------------------------------------------//
//GLOBAL VARIABLES -----------------------------------------------------------------------------//
   int16 MotorCntlLeft, MotorCntlRight, AuxCntlWord;
//--ARRAYS -------------------------------------------------------------------------------------//
rom int16 SineTable[72] = {0x8000,0x8b27,0x963a,0xa120,0xabc7,0xb618,0xc000,0xc96a,0xd246,
                           0xda82,0xe20d,0xe8d9,0xeed9,0xf401,0xf847,0xfba3,0xfe0e,0xff83,
                           0xffff,0xff83,0xfe0e,0xfba3,0xf847,0xf401,0xeed9,0xe8d9,0xe20d,
                           0xda82,0xd246,0xc96a,0xc000,0xb618,0xabc7,0xa120,0x963a,0x8b27,
                           0x8000,0x74d8,0x69c5,0x5edf,0x5438,0x49e7,0x4000,0x3695,0x2db9,
                           0x257d,0x1df2,0x1726,0x1126,0x0bfe,0x07b8,0x045c,0x01f1,0x007c,
                           0x0000,0x007c,0x01f1,0x045c,0x07b8,0x0bfe,0x1126,0x1726,0x1df2,
                           0x257d,0x2db9,0x3695,0x4000,0x49e7,0x5438,0x5edf,0x69c5,0x74d8};
rom int16 SineTable[36] = {0x8000,0x963a,0xabc7,0xc000,0xd246,0xe20d,0xeed9,0xf847,0xfe0e,
                     0xffff,0xfe0e,0xf847,0xeed9,0xe20d,0xd246,0xc000,0xabc7,0x963a,
                           0x8000,0x69c5,0x5438,0x4000,0x2db9,0x1df2,0x1126,0x07b8,0x01f1,
                           0x0000,0x01f1,0x07b8,0x1126,0x1df2,0x2db9,0x4000,0x5438,0x69c5,};
//FUNCTION PROTOTYPES --------------------------------------------------------------------------//
//void Rover_Control_Xmit()
//INTERRUPTS -----------------------------------------------------------------------------------//
//Subroutines ----------------------------------------------------------------------------------//
   int16 RoverCntlData[3];
      RoverCntlData[0] = MotorCntlLeft;
      RoverCntlData[1] = MotorCntlRight;
      RoverCntlData[2] = AuxCntlWord;
   int8 wd=0;
   int16 DataWord;
      int8 bt=0;
      int1 DataBit;
         int8 ArrayIncr = 2;
          int8 i=0;
         int16  *ptr, ptrMax;
          ptr = &SineTable;
         ptrMax = ptr + 36;
   for(wd=0; wd<3; wd++)
      DataWord = RoverCntlData[wd];
      for(bt=0; bt<10; bt++)
         DataBit = shift_left(&DataWord,2,0);
         if(DataBit)
            ArrayIncr = 3;
            ArrayIncr = 2;
          for(i=0; i<18; i++)
              while(!LEMPTY);
            output_high(PIN_B13);
            dac_write(DAC_LEFT,*ptr);
              ptr = ptr + ArrayIncr;
            output_low(PIN_B13);
            if(ptr == ptrMax)
               ptr = ptr - 36;
//   int1 VideoFieldSync=0;
//   int8 VideoFieldCount=0;
//   int1 pulse=0;
   ACLKCON = 0x0480;                  //ACLKCON control word for 22,118,380 Hz
//   PLLFBD = 0x002E;
   DAC1DFLT = 0x8000;                  //DAC default mid point
   setup_wdt(WDT_OFF);
   setup_timer1(TMR_DISABLED);
   setup_timer2(TMR_INTERNAL, TMR_DIV_BY_8);
   setup_timer3(TMR_INTERNAL);
   setup_adc_ports(sAN0 | sAN1);
   setup_adc(ADC_CLOCK_INTERNAL | ADC_TAD_MUL_31);
   setup_dac(DAC_LEFT_ON, 1);
// Main Code
    while (1)
   MotorCntlLeft= 0xfff0;
   MotorCntlRight = 0xfff0;
   AuxCntlWord = 0xfff0;
   if(!input(PIN_B5))
      Rover_Control_Xmit();
And the .h file
#include <33FJ64GP802.h>
#device ICD=TRUE
#device PSV=16
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOBSS                    //No boot segment
#FUSES NORBS                    //No Boot RAM defined
#FUSES NOWRTSS                  //Secure segment not write protected
#FUSES NOSSS                    //No secure segment
#FUSES NORSS                    //No secure segment RAM
#FUSES NOPROTECT                //Code not protected from reading
#FUSES PR_PLL                   //Primary Oscillator with PLL
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES XT                       //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#FUSES NOOSCIO                  //OSC2 is clock output
#FUSES NOIOL1WAY                //Allows multiple reconfigurations of peripheral pins
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
#FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
#FUSES NOWINDIS                 //Watch Dog Timer in Window mode
#FUSES PUT128                   //Power On Reset Timer value 128ms
#FUSES NOALTI2C                 //I2C mapped to alternate pins
#FUSES ICSP1                    //ICD uses PGC1/PGD1 pins
#FUSES NOJTAG                   //JTAG disabled
#FUSES DEBUG                    //Debug mode for use with ICD
#use delay(clock=44236800,crystal=7372800)
I am using PCD v4.121 with MPLAB v 8.63 and RealICE
I got the correct output by switching to the 36 element array but the math says it should be 72 elements.
Thanks for any insight.
Mick
mkent
PostPosted: Thu Jun 09, 2011 7:49 pm     Reply with quote
A picture of the DAC output. The first 540 degrees represents a high and is at 3600 Hz, the next 360 degrees repesents a low and is at 2400 Hz. Note the cursors and the readout.
Mick[/img]
