phil1 Guest
interrupt with pic16f876 |
Posted: Thu Mar 29, 2007 2:25 pm |
help,
i use compiler pcwh 4.017, pic16f876 . The interrupts ccp1 and ccp2 doesn't work . I tried the example programme EX_CCPMP from ccs, and it still not work. if i do a test " interrupt_active(int_ccp1)", it appear that the interupt is not active ( i have before write "
setup_ccp2(CCP_CAPTURE_FE)
enable_interrupts(int_ccp2)
enable_interrupts(GLOBAL)
i'm quite sure that the program is ok. is it some thing special to configure with the compiler???
thanks for any help
philippe |
Posted: Thu Mar 29, 2007 4:48 pm |
Vs. 4.017 is writing to the wrong register addresses for CCP1CON
and CCP2CON. I would ask CCS for an upgrade to a working version.
If they won't do that, then get vs. 3.249. But you need some other
version than 4.017.
Code for vs. 4.017. This has bugs.
Code: | ... setup_ccp1(CCP_CAPTURE_RE);
012A: MOVLW FF
012B: BCF 03.5
012C: MOVWF 2E
013A: BSF 2E.2
013B: MOVF 2E,W
013C: BSF 03.5
013D: MOVWF 07
013E: CLRF 44 // Bug
013F: MOVLW 05
0140: MOVWF 44 // Bug
...... setup_ccp2(CCP_CAPTURE_FE);
0141: BCF 03.5
0142: BSF 2E.1
0143: MOVF 2E,W
0144: BSF 03.5
0145: MOVWF 07
0146: CLRF 45 // Bug
0147: MOVLW 04
0148: MOVWF 45 // Bug
Code for vs. 4.030:
012A: MOVLW FF
012B: BCF 03.5
012C: MOVWF 2E
013A: BSF 2E.2
013B: MOVF 2E,W
013C: BSF 03.5
013D: MOVWF 07
013E: BCF 03.5
013F: CLRF 17
0140: MOVLW 05
0141: MOVWF 17
0142: BSF 2E.1
0143: MOVF 2E,W
0144: BSF 03.5
0145: MOVWF 07
0146: BCF 03.5
0147: CLRF 1D
0148: MOVLW 04
0149: MOVWF 1D |
Code for 3.249:
0124: MOVLW FF
0125: BCF 03.5
0126: MOVWF 2E
0132: BSF 2E.2
0133: MOVF 2E,W
0134: BSF 03.5
0135: MOVWF 07
0136: BCF 03.5
0137: CLRF 17
0138: MOVLW 05
0139: MOVWF 17
013A: BSF 2E.1
013B: MOVF 2E,W
013C: BSF 03.5
013D: MOVWF 07
013E: BCF 03.5
013F: CLRF 1D
0140: MOVLW 04
0141: MOVWF 1D
phil1 Guest
interrupts |
Posted: Fri Mar 30, 2007 4:52 am |
thanks a lot
the first correction should be to write this part of code in assembler |
