Posted: Wed Apr 04, 2012 7:23 am |
The benefit of how you did it is that you skip the last delay_ms() call when you have a good number.
Just for clarity's sake, this is a visual of what break does:
while(TRUE){
if(input(PIN_B2) == 0){
count++;
}else{
count = 0;
if(count == DEBOUNCE_COUNT){
delay_ms(DEBOUNCE_PERIOD_IN_MS);
/* BREAK JUMPS YOU TO THIS SPOT */
Since you didn't provide any code other than your scanfaces(), wait_for_keypress_1(), and wait_for_keypress_2() methods, I can't really comment on the rest of your inquiry.
The way I understand how your code works is that you just loop infinitely until you get a debounced low. Is that the intention? |
rems
Posted: Wed Apr 04, 2012 7:46 am |
I have a very bouncy switch. It is homeade and literally has a ball within a cage that has 6 possible positions to be in. I need to debounce each of those positions. When the ball is in position, an i/p is sensed "LOW" and the debounce should start. In the debounce, I want to check and recheck that the i/p is still low. I may need to do this several times or just increment the delay between checks. Like I said it's a very bouncy switch.
Here is my complete code.
#include <16F887.h>
#fuses INTRC_IO //use internal oscillator
#fuses NOWDT //No watch dog timer
#fuses PUT//
#fuses BROWNOUT//reset chip if voltage falls
#fuses MCLR//master clear enabled
#fuses NOLVP
#use delay(clock=8000000)
#define DEBOUNCE_PERIOD_IN_MS 100
#define DEBOUNCE_COUNT 2
#define resbutt pin_B5 //restart 'c' condition
//if condition is obtained turn on led
#define sleepbutt pin_D7
//**********************************Debounce Functions
void wait_for_keypress_1(void)
int count=0;
if(input(pin_B2)==0)
count++;
else{
count=0;
void wait_for_keypress_2(void)
int count=0;
if(input(pin_B3)==0)
count++;
else{
count=0;
void wait_for_keypress_3(void)
int count=0;
if(input(pin_B4)==0)
count++;
else{
count=0;
/*****************************************************************Declare a function that will SCAN the faces of the puzzle box*******************/
int8 scanfaces(void)
int led_output=0;
int face;
// ************************************Configuring cage to sense faces
OUTPUT_low(PIN_B1);
//************************************ Checking Face 1
if(input(PIN_B2)==0) {
wait_for_keypress_1();
bit_set(led_output,0);
else {
bit_clear(led_output,0);
//************************************ Checking Face 5
if(input(PIN_B3)==0) {
wait_for_keypress_2();
bit_set(led_output,1);
else{
bit_clear(led_output,1);
//*************************************** Checking Face 4
if(input(PIN_B4)==0) {
wait_for_keypress_3();
bit_set(led_output,2);
else{
bit_clear(led_output,2);
// **************************************Configuring cage to sense second 3 i/p's
OUTPUT_low(pin_B2);
//*************************************** Checking Face 2
bit_set(led_output,3);
else{
bit_clear(led_output,3);
//**************************************** Checking Face 6
bit_set(led_output,4);
else{
bit_clear(led_output,4);
//****************************************** Configuring cage to sense last i/p
OUTPUT_LOW(PIN_B3);
//****************************************** Checking Face 3
bit_set(led_output,5);
else{
bit_clear(led_output,5);
//*********************************************Making 6 unique possibilities
if (led_output==0b00000001)
face=1;
if (led_output==0b00001001)
face=2;
if (led_output==0b00100000)
face=3;
if (led_output==0b00110100)
face=4;
if (led_output==0b00001010)
face=5;
if (led_output==0b00110000)
face=6;
return(face);
//*****************************************Password = 512346
int sh1=1,sh2,sh3,sh4,sh5,sh6; // sw1=1 for starting first condition.
while(1){
if(scanfaces()==5&&sh1==1) //if butt 1 = 1 AND sw1=1(which it does to start) then
sh2=1; //Allow second condition
if(scanfaces()==1&&sh2==1)//if butt 2=1 AND sw2=1(it only will if butt 1 was pressed) then
sh3=1; //Allow third condition
if(scanfaces()==2&&sh3==1) //if the three condition are obtained turn the led on.
sh4=1;
if(scanfaces()==3&&sh4==1) //if the three condition are obtained turn the led on.
sh5=1;
if(scanfaces()==4&&sh5==1) //if the three condition are obtained turn the led on.
sh6=1;
if(scanfaces()==6&&sh6==1) //if the three condition are obtained turn the led on.
output_high(pin_C5);
sh6=0;
else if(scanfaces()==6&&sh6!=1) //if the algorithm is not executed wait for restart. (if butt 3=1 and sh3 does NOT =1 then )
sh1=0; //set all to zero
sh2=0; //which ensures that only the proper combo(sequence) will activate
sh3=0;
sh4=0;
sh5=0;
sh6=0;
if(input(resbutt)==1) //restart entering sequence of buttons. if reset button pushed
output_low(pin_C5); //led will turn off
sh1=1; //allow condition start again
Because my "cage switch" shares common pins, I use my "scanfaces" to toggle i/p's and o/p's. I then give each a unique ID with the "bitset" and then return the value of each for use in the state machine, in my main program.. All works beautifully except of course for the debounce. |
RF_Developer
Posted: Wed Apr 04, 2012 9:39 am |
The basic idea is that your main while loop just goes round and round. It checks if things need doing: it checks buttons, it checks for incoming data that needs to be processed, it measures, it outputs stuff and so on. None of these things should ever wait anything other than a few tens of us or so. Instead they check and if nothing to do they do nothing in that loop.
Most of the time your main loop does nothing much. Only if something needs servicing: display needs updating, someones pressed a button, a message had been receved, a timed event has been flagged up and so on; does your main loop actually do any processing. That means you'll check (or poll) everything on every loop.
So. you never "wait for a key press". You note a key has been pressed; if so do stuff and set a counter so that the keys will be ignored for say 50ms worth of loops before looking at the keys again. Longer for your caged ball switch. Using a timer, or clock tick based software timer will help there.
With debouncing there actually isn't much point in checking the contact is still where you first detected it after a time. The bounce happens when a contact is first made or broken and then for a while un-makes or un-breaks repeatedly. So only the first detection is relevant, then hold off from making further detections for at least the longest time you'll get bounce, which for some switches (and it varies from switch to switch of one type and from one type of switch to another) may be longer than 100ms.
Your caged ball will be tricky as normal switches work with some form of spring arrangement that biases them in to on position or another. The ball however relies on gravity alone, and it may get dirty and not make good contact. Have you designed the ball switch to be break-before-make? If so then you should be able to check it goes to a "none connected" state between one face and another and so, if it does go into the "none" state and back then nothing has really happened... or has it? How you interpret that is dependant on your application. You almost ceratainly can't do that if you are multiplexing the pins with another function.
This is the simplest form of "co-operative multitasking". Where each thing that has to be done: e.g. detect keys, update display, read serial, measure voltages, send formatted data, is regarded as a seperate task and your loop is the most simple form of round-robin scheduler. No "task" should ever wait if it can help it, and certainly not if it has nothing to do. Even ADC reads can, if required, be started on on loop and read back on the next, eliminating the need to wait for the ADC to convert. I have one simple app that does this. Though I confess on my others waiting for the ADC typically forms the greatest single time in the overall loop execution time.
RF Developer |
rems
Posted: Thu Apr 05, 2012 6:50 am |
A lot to think about...That is some great stuff for me consider. With a lot of hard work and dedication to this stuff, I will eventually understand and appreciate everything you wrote.
I will keep at it.
Thank you for your insight. |
