Posted: Tue Mar 08, 2005 3:19 pm |
Try a more simple test program, and also include a #fuses statement.
Try sending characters to the PIC by typing in a terminal program.
You should see them echo'ed back to the terminal.
Code: | #include <16F767.h>
#fuses HS, NOWDT, NOPROTECT, BROWNOUT, PUT
#use delay(clock=20000000)
char c;
c = getc();
putc(c);
Note that this PIC doesn't support Low Voltage Programming, so the
LVP and NOLVP fuses are not an issue here. |
chipp
It Works! |
Posted: Thu Mar 10, 2005 11:46 am |
Thank you, simple as it is it works, it seems like setting the TRIS on Port C was somehow interferring, so I commented it out:
// set_tris_c(0x10000000); // C7 rx, C6 tx
fuzzy
Posted: Thu Mar 10, 2005 2:54 pm |
I had a similar problem, my pic received all what he transmitted!!
I solved setting in a correct way TrisC.
in your case 0x10000000 is a hexadecimal number not a binary one.
tri to set 0b10000000 or 0x80 in TRISC |
